This weekend i got round to fitting my new sports pack arches and alloys. So pleased with the paint finish on them.
I used mini spares templates to work out where to cut from wings and drill holes.
Angle grinder 1mm blade along the cut line then reformed a new arch lip using grips. Painted lip
KAD steering rack limiters were installed to prevent alloys rubbing the inner wing. You lose one whole turn on the steering wheel doing this but makes it safer for the tyres.
At the rear remove fuel tank from the left to gain access to the inside of panel
The sports pack alloys grip the road so much better than the 4 inch rover alloys - They have eliminated all the body roll i had previously.
Next job is to fit my new adjustable heavy duty front tie bars and bushes. Both steering rack gaiters are perished and split so will do them next weekend along with new track rod ends
I plan to remove the mini cooper decal from the boot and fit a winged badge. Also want to remove the 1.3 badge as it looks untidy due to the chrome worn off.
