998 Mini Engine Pipe 270 Cam Bit Flat Under 2500 Rvs
Posted 30 January 2012 - 07:05 PM
i know the cams kick in later than standard but is there any way of improving the performance lower down the rev range.
theres plently of power above 3000 rpm,
just wondering if i could do anything to improve this,
Currently ruining a standard 1"1/2 carb soon changing to a 1"3/4 that will be modified as the vizards guide.
anything else i could do. any need, jet.
Posted 30 January 2012 - 07:21 PM
The only way to obtain better performance at lower revs is to fit a more suitable cam. With a 270 cam you should expect to be keeping the revs at over around 3000 rpm at all times. In a 998 a 270 is quite an aggressive cam.
Posted 30 January 2012 - 07:51 PM
from my rolling road chart it goes up from 1to 2 thou then drop then shoots up.
i just don't like the drop. love when it kick in and the lush noise it makes just before 3000.
just wondering if i could reduce the drop.
Posted 30 January 2012 - 07:55 PM
You'll have to accept it as it is or change the cam for a 'softer' one.
Posted 30 January 2012 - 07:58 PM
just thought i would ask. see if there anything i could do.
i do have a veneer pully could i alter the valve timing with that.
just an idea.
if you don't ask you don't learn.
thanks for the advise. steve
Posted 30 January 2012 - 08:03 PM
As it's a 998 you can change the cam without taking the engine out.
A really good cam for a 998 is the early Cooper 'S' 510 profile and that will pull from 2000 rpm, be strong from about 3200 and peak at about 5600 rpm.
Posted 30 January 2012 - 08:08 PM
just thought i would ask. thanks for the advise, still learning.
i like the cam and the power it delivers.
with a few more tweeks it should be good for a few more BHP.
i think i got the bug lol.
Posted 30 January 2012 - 08:12 PM
Posted 30 January 2012 - 08:16 PM
Altering the cam timing won't help and could make it worse.
Who said anything about altering the cam timing...........
If you what to give up on this cam even before trying to get it working right, a better choice would be the MG cam. Pulls from 2000 but doesn't stop until well over 6000............
He did, he said he has a Vernier Pulley and could alter the valve timing (= cam timing). Please read before replying with implied criticism.
Posted 30 January 2012 - 08:33 PM
Posted 30 January 2012 - 08:46 PM
i was just wondering if the dip could be fuelling due to only having a 1"1/2
changing the diff would be a good idea.
what ratio would u recommed.
currently i have a 3.1 diff.
Posted 30 January 2012 - 08:49 PM
the head was skimmed and check by a cylinder head specialised.
Posted 30 January 2012 - 08:58 PM
will ring him tomz and find out.
Posted 30 January 2012 - 09:43 PM
Posted 30 January 2012 - 10:45 PM
I also have a lightened flywheel but i've noticed that if i let the revs drop suddenly from a high rpm with the clutch in, it stalls, don't whether this is because of the flywheel or whether i just can't drive. lol
