Ttemplate For Pocketing A 998 Block
27 replies to this topic
#1 booton
booton
  • 913 posts
Posted 31 January 2012 - 10:48 PM
read in here some where that some one managed to find a template for a 998 pocket
going to be pocketing a block again soon and last one i had done were 3cc.
if some one could send me a link of a copy of the template. that would be great as long as it is for the larger valve 940 heads.
many thanks if anyone has a link or copy.
my email is [email protected]
#2 charie t
charie t
  • 3,153 posts
Posted 31 January 2012 - 11:22 PM
Take the block being pocketed and the head the machinist. They will be able to sort it from that
#3 Spitz
Spitz
  • 1,716 posts
Posted 02 February 2012 - 03:54 PM
I had thought it was only #1 and #4 that needed pocketing......if at all. ( by if at all, I mean if no high lift cam or 1.5 rockers are used )
#4 bmcecosse
bmcecosse
  • 9,699 posts
Posted 02 February 2012 - 07:57 PM
It's MUCH easier and a lot less destructive to simply sink the 4 exhaust valves into the head by 40 thou. That's IF it needs it - measure up first...... With a standard lift cam/standard rockers you need 320 thou clearance. Some 940 heads already have that clearance due to valve seat recession.......
#5 Spitz
Spitz
  • 1,716 posts
Posted 02 February 2012 - 10:08 PM
Hate to tell you this spitz, but all four cylinders have exhaust valves >_<
Just having a look at the 998 head gasket, will show you :-)
WHAT?!
#6 Spitz
Spitz
  • 1,716 posts
Posted 03 February 2012 - 05:41 AM
I should have put a smiley face on that I suppose.....
(My "what" was meant in jest)
#7 bmcecosse
bmcecosse
  • 9,699 posts
Posted 03 February 2012 - 10:29 AM
I don't believe the standard ex valve hits the block on a 998.........
#8 Ivor Badger
Ivor Badger
  • 846 posts
Posted 03 February 2012 - 01:19 PM
Would there be any logical reason for that?
#9 Rusty1182
Rusty1182
  • 389 posts
  • Local Club: Mini Allsorts
Posted 06 February 2012 - 08:51 PM
how do you sink the exhaust valves
#10 booton
booton
  • 913 posts
Posted 06 February 2012 - 09:44 PM
with my high lift cam it need to be sank 3mm
#11 booton
booton
  • 913 posts
thanks for the template much appreciated.
#12 bmcecosse
bmcecosse
  • 9,699 posts
Posted 06 February 2012 - 10:02 PM
The valves are easily sunk into the head - 5 minute job with a 45 degree countersink in a pillar drill - it doesn't ruin the block, or expose the top ring to hot gases..... Using a 940 head on a 998 is best done with a standard lift camshaft - MG Metro is thus ideal for the job. The relatively huge valves means you don't need to lift them high! I don't believe you need 3mm deep pockets - where does that come from ?? You will be right down at the top ring - don't do it! A standard 998 Mini head - the exhaust valves go down the bores - they can't hit the block......
#13 Rusty1182
Rusty1182
  • 389 posts
Posted 06 February 2012 - 10:05 PM
So 40 thou would be plenty
But just for reference if I didn't sink the valves how deep would u make the pocket
#14 bmcecosse
bmcecosse
  • 9,699 posts
Posted 06 February 2012 - 10:08 PM
First it was 3mm - now it's 40 thou (= 1mm) - where are you getting the figures from?? You need to measure first - not just guess....... What cam are you using?? Do you know the cam lift??
Also -do you know the distance from the head of the exhaust valves to the face of the cylinder head? You need to measure this.......accurately.
Edited by bmcecosse, 06 February 2012 - 10:09 PM.
#15 Rusty1182
Rusty1182
  • 389 posts
Posted 06 February 2012 - 10:10 PM
Mg metro cam
