Washer Bottle Location?
13 replies to this topic
#1 Nicks217
Nicks217
  • 91 posts
Posted 01 February 2012 - 12:34 PM
Hi guys just a quick question.
I have a 1993 Sprite which has the washer bottle located in the boot?
Is this original and is there any reason why its better in the boot?
Apart from it never warms up in the freezing cold!
Thanks.
#2 R1minimagic
R1minimagic
  • 4,660 posts
Posted 01 February 2012 - 12:36 PM
Injection cars have it in the boot as the ECU is fitted where it used to be!
#3 Gunnsie
Gunnsie
  • 294 posts
Posted 01 February 2012 - 12:41 PM
Mines a Sprite with a carb engine and mine is in the boot too.
Chris
#4 Nicks217
Nicks217
  • 91 posts
Posted 01 February 2012 - 12:46 PM
Chris
Just wondering if its original to the sprites?
#5 surfblue63
surfblue63
    TMF fantasy F1 winner 2012
  • 2,539 posts
Posted 01 February 2012 - 01:01 PM
Yes, all Minis from 1993 on, following the introduction of the SPi Cooper, had their washer bottle mounted in the boot. This includes Carb 1275 Sprites and Mayfairs.
If you are worried about it freezing up then just add some more winter washer fluid instead of water.
#6 Nicks217
Nicks217
  • 91 posts
Posted 01 February 2012 - 01:11 PM
Okay thank you for all your help.
Best leave it in the boot then :)
#7 bluesprite
bluesprite
  • 282 posts
Posted 01 February 2012 - 01:20 PM
Mine's an August 1992 carb sprite and has it in the boot
#8 surfblue63
surfblue63
  • 2,539 posts
Posted 01 February 2012 - 01:29 PM
That should read 1992 onwards, not 1993.
#9 james962
james962
  • 2,677 posts
Posted 01 February 2012 - 01:32 PM
I'm thinking about relocating my washer bottle into the boot, however am worried about chance of leakage onto the battery? Or are they mounted right inside the wheel arch? Anybody got any pictures to hand?
#10 Gunnsie
Gunnsie
  • 294 posts
Posted 01 February 2012 - 01:45 PM
They are mounted just behind the righthand rear light cluster.
#11 Nicks217
Nicks217
  • 91 posts
Posted 01 February 2012 - 01:50 PM
I have found that the washer bottle shouldent leak into the battery.
It would run down the side of the battery 1st.
#12 newnham500
newnham500
  • 221 posts
Posted 01 February 2012 - 01:53 PM
um, if you were going to move it to the engine bay. where would you put it, which is more than likely the reason its in the boot
#13 The Otter
The Otter
    The artist formally known as j322overthetop
  • 620 posts
Posted 01 February 2012 - 03:30 PM
I've got a May 92 registered 998 and mines in the boot, my mate has a Jan 92 registered 998 and its in the engine bay, would seem most minis of this era are a bit mix and match :P
#14 L400RAS
L400RAS
  • 2,479 posts
  • Local Club: Lincolnshire Mini Owners Club
Posted 01 February 2012 - 06:01 PM
Changeover was August 1992 i believe (when all cars went to 1275 engines, and the Sprite replaced the city model)
Edited by L400RAS, 01 February 2012 - 06:01 PM.
