Front Tie Bar Set Up/bottom Arms
Posted 02 February 2012 - 04:27 PM
I've just fitted the front adjustable tie bars and negative camber arms. Now i'd like to know a good way of roughly getting it right so i can drive it over to a place to get set up properly. Currently the tie bars are set to just above standard length, sorry i am rather puzzled with castor and toe so i wouldn't know where to go, I understand slight toe out at the front is good?
Also when i do have it set up what sort of geometry should i be asking for? It is for fast road use, spec atm is...
-Adjustable tie bars
-1.5 negative camber arms
-New bushes in these both
-Gaz adjustable shocks
-13x7 supalites (however i may later in the year be tempted by 10s)
I think thats it for what i have changed, the rest is standard.
Any help would be greatly appreciated yet again :)
Posted 02 February 2012 - 11:48 PM
Posted 03 February 2012 - 12:49 AM
Posted 03 February 2012 - 09:23 AM
your camber will be fixed as you did not buy adjustable which you should have done in my opinion
your tracking will probably be way out toeing in
what i done with my FALCONS is measure the middle of the tyre across to other middle ( theres a groove around tyre )
i done this about 4" up from the ground, then done the same at the rear and adjust track arms til aprox both the same mearurement
so i know its about straight on, also played around with string round the car wheels. see how alighnment was pointing on each wheel
car drives good
Posted 03 February 2012 - 10:28 AM
Posted 03 February 2012 - 11:21 AM
First VERY IMPORTANT point - have you fitted the longer track rod ends that are essential with neg camber arms??? If not - the thread length is dangerously low - get a set NOW.. The tie rods should be set to standard length - certainly not longer. Standard lengthy is fine - pulls the castor up nicely with the longer bottom arms.
After fitting adjustable lower arms myself not too long ago, I'm not so sure on this point, nnless your running 2 degrees or more of neg camber.
How many flats/threads would you consider too few?
With 1.5 degree fixed arms there's going to be barely any negative camber at all on the wheels, so I can't really see the longer track rod ends being required.
Posted 03 February 2012 - 01:12 PM
I fitted new track rod ends to the car, I'm not sure wether they are longer but I bought them with the rest of the parts mentioned from a show so would have thought they'd be ok? However minispeed have been extremely crap so far
Posted 03 February 2012 - 01:27 PM
for some reason i didnt realy need them on mine even with 2 deg camber
there was still half inch thread, but i changed them for the sake of 12 quid
Posted 03 February 2012 - 01:31 PM
Sorry about going so in depth, i like to understand everything i am doing and not just do it cause uncle tomcobbly said so.
Posted 03 February 2012 - 02:20 PM
Posted 03 February 2012 - 02:40 PM
Posted 03 February 2012 - 09:02 PM
as dont do it all the time
with settings i would go for
one and half neg camber, 1/16 toe out, 4 caster
thats for 10 or 12 inch wheels
if doing track days you will need the back end done 1/16 toe in and half deg neg camber
if you dont do this for the track the back tends not to come round
maybe lower the car some, mine is, you will need adj shocks as well
Posted 03 February 2012 - 09:21 PM
Posted 03 February 2012 - 09:30 PM
Posted 04 February 2012 - 12:25 PM
set the adjustable tie-rods to the standard length.. also set the bottom arm to the standard length.
then get it setup.
Longer track rod ends are recommended.
Road useage then 1.5 degs neg camber is the max I would set them up to on the front - and this would be for 10" wheels
12" wheels less, 13" less than 12"....
Camber is adjusted with the bottom arms.
Castor - vital that this is equal on both sides... more castor = more self centring of the steering, harder to turn, but more camber when you do turn in... I aim for around 5degs but this must be matched on each side, again the bigger the wheel the more castor seems to help.
once you have set your camber and castor - (note that adjusting camber with knock out your castor and vice versa), you then reset the tracking to a max of 1mm toe out on the front (assuming all new bushes)
at the rear, generally less camber than the front. and around 1mm toe in: now this *must* be measured on each wheel (0.5mm toe in on each rear wheel), very weird things can result if you cannot check the toe of the individual rear wheels when tightening the tolerances up on the rear toe..
Height wise, front you want to have a minimum of a fingers width between top arm and bump stop..... the back needs to be higher than the front.
Bits of string and such like is really basic and sadly often results in less than satisfactory results,,,, and, although it may sound I am drumming up business.,.. getting it setup *right* does make a world of difference and not expensive...
