Exterior Rubber Fuel Pipe Seal Replacement, How?
Posted 02 February 2012 - 10:43 PM
Does anyone know how to replace it, both off and on? Seems pretty firmly stuck, and i dont wan't to pull it off only to not be able to get the new one on.
Thanks.
Oh, and this is the pre-1996 wider part, as is my car (1989).
Posted 02 February 2012 - 10:46 PM
Posted 02 February 2012 - 11:24 PM
If you can smell/see fuel leaking then it is either the rubber seal on the petrol cap its self has perished, or the petrol neck has rusted though with small pin holes, (this has happened to me on 2 minis ive owned from 1989). I sorted it by removing the tank, rubbing down the rusted pinholed area around the filler neck and using chemical metal to seal it, then put the tank back in place.
Hope that helps!
Posted 03 February 2012 - 04:04 PM
Posted 03 February 2012 - 04:06 PM
Posted 03 February 2012 - 04:20 PM
Funny you say that, i was about to ask a question about that. I wasn't sure if i needed to replace it with a vented or non vented. And that could be it actually, currently it has a cap which i'm not convinced is standard. It fits perfectly, but it's a plastic and metal thing with a plastic cap that rotates over the keyhole-not something i've seen on other mini's and certainly not other 30s. I have a feeling it could be something stolen from a different leyland car to replace the old one (it has the leyland 'L' on it), but yeh ill replace it with the standard chrome vented part.You need a vented fuel cap, you are not using a non-vented are you?
Posted 03 February 2012 - 04:26 PM
This seems to be the right year/mk, but it's non vented, there is an earlier vented part, but apparently thats for mk1/2s? *EDIT* Sorry, forgot to add what i was refering too haha http://www.minispare...id=33983&title=
Edited by Calderwood, 03 February 2012 - 04:35 PM.
Posted 03 February 2012 - 04:31 PM
To remover the fuel tank to take the seal out;
- First make sure your tank isn't full of fuel,
- Then take the spare wheel out and disconnect and remover the battery,
- Then undo the bolt in the bottom left hand corner of the boot just in front of the fuel tank (when looking stood at the back of the car looking into the boot) that holds the fuel tank strap,
- Then unplug the wires that go to the side of the fuel tank for the fuel gauge,
- Then remover the filler cap
- You should now be able to move the fuel tank to get the filler neck inside the boot. Be careful not to move it too far though as the fuel pipe is still connected and you don't want to break the rubber hose. Once the filler cap is inside the boot, put the cap back on so you don't loose any fuel.
- You can now remover the rubber seal.
If you actually want to take the fuel tank out there is a clamp on the fuel pipe that you will need to loosen and then take the hose off. Then put your finger over the hole in the tank while you manoeuvre it out of the boot.
Hope that helps
