Rubber Floor Grommets,
15 replies to this topic
#1 analogue_radio
analogue_radio
  • 4,897 posts
Posted 03 February 2012 - 06:04 PM
I remember there being a few discussions about where you could get these before, I know they aren't strictly mini related and they are just 1" grommets, but you can pick up a pack of 25 pretty cheap here..
http://www.ebay.co.u...40#ht_642wt_982
Might be helpful for a few of you! I've just bought myself a pack.
#2 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 03 February 2012 - 06:09 PM
http://www.autospark...cPath=92&page=3
I'm pretty sure I found that the 1 inch ones weren't snug though. Can't remember exactly. I got a few different sizes to decide which one was best suited for it.
#3 analogue_radio
analogue_radio
  • 4,897 posts
Posted 03 February 2012 - 06:18 PM
Well I'm sat in the Uni library 'working' and I couldn't remember what size they were exactly! I'm sure they'll plug a few holes.
#4 james94
james94
  • 337 posts
  • Local Club: eastbourne mini club
Posted 03 February 2012 - 06:27 PM
in all honestly leave them out they drain water which in a mini you will invetably get in the car so in leaving them out the water can drain preventing the floor from rotting also remove your carpet until the summer as it holds a huge amount of water form coondensation etc :)
#5 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,080 posts
  • Name: Neil
Posted 03 February 2012 - 06:35 PM
So unless you drive the car in dry weather only you will get wet carpets anyway. Providing your door seals are in good order along with no rusty holes then you should be ok with the plugs fitted.
We never had any issues with either of my wifes two minis. If they are rubber plugs and fresh then you can easily pop them out.
And just to add if you really want the correct size and cannot source them cheaply then SC Parts sell the correct sizes but they are not cheap unfortunately.
#6 mk1leg
mk1leg
  • 9,343 posts
Posted 03 February 2012 - 06:38 PM
yes lucas parts do a complete car set...................... http://www.holden.co...agName=Grommets
#7 Cerberus
Cerberus
  • 989 posts
Posted 03 February 2012 - 07:19 PM
What about water off the road or spray from other vehicles? Also be a pretty cold jet of air coming right up your trousers in the winter.
I've also not had wet carpets since I sorted out all my leaks, and mine is an everyday car.
#8 james94
james94
  • 337 posts
Posted 06 February 2012 - 04:45 PM
i just have no carpets in over winter and have my rubber car mats in as that stops the draft and any water getting in but the water can get out underneath :), you have all been very lucky if your cars dont leak lol. was just a thought
regards james
#9 Cerberus
Cerberus
  • 989 posts
Posted 06 February 2012 - 05:23 PM
Surely its better to solve the reason why its leaking rather than just enabling drainage? :D
#10 james94
james94
  • 337 posts
Posted 06 February 2012 - 05:25 PM
yeah it is but is a mission as my car for some rerason is like a siv but there is no obvious places i can see water coming in lol
#11 giner88
giner88
  • 914 posts
Posted 06 February 2012 - 09:06 PM
i know this feeling, i thought i had solved the problem then it rained today and i'm back to square one, i'm sure its watertight buuut its just not. so weird. so your not alone, i am apart of the siv club to.
#12 Mini-Mad-Craig
Posted 06 February 2012 - 09:14 PM
I'm welding them up.
#13 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 06 February 2012 - 09:21 PM
£7.00, + £2.00 delivery for 25 grommets! Are you mad? Another ebay millionaire in the making there. 1" grommets are a standard electrical size, I'd be amazed if you paid that much for them at B&Q! Go to an electrical wholesaler, they are about 10p each.
#14 Bash Master
Bash Master
  • 150 posts
Posted 07 February 2012 - 09:40 AM
I got mine from maplins for about 3 quid. Just a little undersize but nothing a bit of silicone can't sort.
#15 joakwin
joakwin
  • 958 posts
Posted 07 February 2012 - 02:15 PM
mine used to leak bad but i cut out all the rusty panels and have been welding everything new in, replaced half the sheet metal on that thing now, lol
but i know it will last,
mini's are a car of joy,
