Restoring Wood Dash And Door Panels
4 replies to this topic
#1 Island Mini
Island Mini
  • 448 posts
  • Local Club: Wish there was one
Posted 03 February 2012 - 09:53 PM
the wood in my 1275 is a bit cracked and faded and i wanted to completely restore it anyone know a process or guidelines to do this, i was guessing some time of lacquer.
#2 Klevdo2202
Klevdo2202
  • 615 posts
Posted 03 February 2012 - 10:17 PM
Did you watch Wheeler dealer when they had the Jaguar XJS? the veneer on the centre console had cracked, so Edd bought some thin stuff that looked similar and stuck it on using a vaccum......
#3 Island Mini
Island Mini
  • 448 posts
Posted 04 February 2012 - 04:17 AM
hmm i tried today sanding the finish off and clear coat rattle canning it, i looks alright i dont know how it would look with more coats though. Whats the easiest way of possibly removing the old rubbish finish, is there a paint stripper?
#4 surfblue63
surfblue63
    TMF fantasy F1 winner 2012
  • 2,539 posts
Posted 04 February 2012 - 04:39 AM
I wouldn't use paint stripper, it will soak into the wood and you will never get it out. The result could be staining which you don't want and any residue could affect the new laquer. The following link explains the best method.
http://www.doityours...-from-furniture
#5 stevede
stevede
    As seen on TV
  • 1,164 posts
  • Local Club: None
Posted 04 February 2012 - 07:46 AM
I sanded some door cappings down which I then carbon wrapped.
Sanding the laquer to get a stable base is straightforward. The thing you need to be careful of of that the veneer is very thin and once you are through the laquer, it can be a matter of seconds before you are through the veneer itself and down to the base wood, especially if using power sanders.
If the wood itself is cracked, then the suggestions above regarding stripping & replacing the veneer will be needed.
Or if you are into the carbon look. Might be an option for you.
Good luck
Regards
Steve
