Using A Landrover Hs6 On A Mini
6 replies to this topic
#1 booton
booton
  • 913 posts
Posted 05 February 2012 - 11:00 AM
has any one used one the hs6 carbs of a landrover v8.
the landrover uses two hs6, They are handed,
just wondering if any one has used one if there could be any problems.
#2 Artful Dodger
Artful Dodger
    " I AM THE SPECIAL ONE"
  • 4,435 posts
Posted 05 February 2012 - 11:07 AM
single hs6 are good for minis, twins would be over kill :)
#3 rids
rids
  • 670 posts
Posted 05 February 2012 - 11:08 AM
i ran one on a 1380 back in the 80's, the only issue i had was when it was getting set up on rolling road rather than change needles, we filed a slight flat on it untill mixture was reading right. if i remember right it had around 100bhp at the wheels. 1380, big valve head, nitrided and balanced crank, lightened and balanced flywheel, 544 cam and an aldon dizzy
#4 booton
booton
  • 913 posts
Posted 05 February 2012 - 11:12 AM
i was recommend by my rolling road tunner to get a hs6 for my 998 with 940 head.
so no real problems then. good good, will get one me thinks
#5 bmcecosse
bmcecosse
  • 9,699 posts
Posted 05 February 2012 - 11:35 AM
An HS4 or rather better HIF38 is fine for that engine spec - you will only need the larger HS6 if the engine is approaching 'full race' spec.
#6 Artful Dodger
Artful Dodger
  • 4,435 posts
Posted 05 February 2012 - 11:46 AM
this is true, the hs6, as good as it may be, would be overkill for a road 998. bigger carb doesnt equal more power.:P
#7 booton
booton
  • 913 posts
Posted 05 February 2012 - 12:30 PM
why would the tuning guy say that i should change my hs4 to a hs6.
