My car came with a 'Stage 1 Kit' when I bought it so I'm fitting the new inlet manifold and exhaust system as the car is going back together...
On the original manifold the one-way-valve for the servo (pictured) was screwed directly into the manifold (the original combined exhaust/inlet cast iron one).
As you can see, the threaded hole in the new manifold is far too large to take the valve. So I am wondering what I can put into that hole that would allow me to connect the servo to the manifold? I've seen a 12H1405 adapter at various suppliers but I can't identify the actual size of it at any of them! The threaded hole in the manifold is about 15mm in diameter.
The (remote) servo has a one-way-valve fitted so it isn't a requirement to fit another on the manifold really if the 12H1405 fits.
Thanks in advance for your help (again)...
