Do You Have To Use High Tensile Nuts On Suspension Parts?
45 replies to this topic
#1 minidave1991-89
minidave1991-89
  • 406 posts
  • Local Club: Charnwood Minis
Posted 06 February 2012 - 12:03 AM
hi all
I've lost the 5/16 nut which attaches the lower arm and the tie bar and need to get new ones. Does it have to be a high tensile nut or will a normal nyloc nut be fine?
cheers, dave
#2 Mini 360
Mini 360
  • 4,933 posts
  • Local Club: Independent
Posted 06 February 2012 - 12:07 AM
I would even if its not really necessary. Do you want to run the risk of a bolt in your suspension snapping throwing the car into a ditch and rollin end over end? Total 1 in a million chance but not to say it can't happen. For all the price of them I would go high tensile
#3 Ethel
  • 26,137 posts
Posted 06 February 2012 - 12:21 AM
I'd expect your nylocs to be SAE grade 5, the same as the bolts. It's the general purpose grade, the bolt (tie rod to bottom arm) will be loaded in shear anywa,y so the nut really just keeps it in place.
#4 bmcecosse
bmcecosse
  • 9,699 posts
Posted 06 February 2012 - 12:24 AM
High tensile bolt - yes, that nyloc nut will be fine.
#5 tiger99
tiger99
  • 8,584 posts
Posted 06 February 2012 - 06:59 AM
SAE grade 5 bolts are not safe and are not used anywhere on a Mini! The correct grade is ISO 8.8, or the obsolete British grade S. The SAE grade 5 means differengt things for different sizes, and in some larger sizes, over 1 inch, it is approximately equivalent to grade 8.8, but in 5/16" size it is dangerously weak.
The strength of the nut MUST be matched to that of the bolt, which does not actually mean that they are the same grade of steel. The nut material will actually be softer. The nut should be marked "8" meaning it is property class 8, and suitable for a grade 8.8 bolt. If you use a grade 10.9 bolt, the nut should be marked "10".
You can use a higher grade nut, but never lower, than the bolt. That is because it is unsafe to have a situation where the nut may be on the point of stripping due to too much torque. It is considerd to be safer to arrange things so that the bolt breaks, always, if overtorqued, to give a very obvious warning.
It is likely that if you buy a 5/16" nyloc in Halfords etc it will be property class 8, but you must check for the correct marking.
#6 minidave1991-89
minidave1991-89
  • 406 posts
Posted 06 February 2012 - 10:06 AM
Thanks for that everyone just wanted to make sure and be safe :proud: anyone know where i can just get 1 nut not 10+?
#7 Ethel
  • 26,137 posts
Posted 06 February 2012 - 11:23 AM
Minis are covered in SAE grade 5, they're the ones with 3 "tick lines" on the head & are equivalent to metric 8.8.
Minispares are reasonable, especially if you're buying other bits.
#8 tiger99
tiger99
  • 8,584 posts
Posted 06 February 2012 - 07:24 PM
Ethel, you are correct again, the three tick marks at 120 degrees is correct for grade 8.8 equivalence, but the problem is with the SAE standard. Grade 5 seems to mean two very different things, or some of my sources of information have it wrong. Or maybe some suppliers, who should know better, have mixed up grade 5 and property class 5 in their data tables.
But will anyone be selling SAE bolts in the UK? I would expect ISO to be more common nowadays.
My first two Minis had bolts with a circular recess and the letter S, and nuts with a line of circles stamped up one side, which were grade S in the old BS system. I think the third had a mixture.
Personally I would buy a pack of 10 nuts, on the basis that I would need them all, sooner or later, probably sooner with a Mini....
#9 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 06 February 2012 - 09:03 PM
The ISO specs sort of translates to the SAE bolts but you cannot go ask for a 5/16 UNF grade 10.9 bolt. The inch size fasteners are still rated by their SAE grade marks. I have NEVER seen variances in what Grade 5 or Grade 8 means. Which manufacturer have you seen or dealt with where the specs are presented differently? EDIT: Please do not include anecdotal stories about Chinese or Korean junk bolts falsely marked with grade marks.
Invest in the high-strength nuts if you want to. It will not hurt anything. However, they are not going to buy you any better performance. The regular nuts are NOT going to catastrophically split and fall off. Nuts typically fail by thread pull-out under high tensile load. That is not present on these components.
EDIT: Those curious can download the fastener guide from Unbrako using the link below. The file is 3.4 Meg so it takes a few moments to download. See page 79.
http://unbrako.com/docs/engguide.pdf
Strength of fasteners is covered by industry standards. In this case SAE J429
Grade 5 in sizes up to and including 1" are rated for an ultimate tensile strength of 120,000 PSI.
Grade 8 in sizes up to 1-1/2" have an ultimate tensile strength of 150,000 PSI.
So... Grade 8 is about 25% stronger than Grade 5 but both are well above what is needed in this application.
Edited by dklawson, 06 February 2012 - 09:17 PM.
#10 tiger99
tiger99
  • 8,584 posts
Posted 06 February 2012 - 11:04 PM
The standards proportion things such that the bolt snaps before the nut thread strips. That is an important safety feature, because otherwise you can't tell if the nut is at the point of failure, and is one of the reasons why the correct nut is not the same grade of steel as the bolt. A softer nut (and in nuts, hardness is as important as tensile strength) may be in a severely weakened condition when the bolt is torqued up, and may fail at any time. If the correct combination of nut and bolt is used there is no possibility of the nut thread getting anywhere near failure.
I don't think the original question was about using grade 10.9, it was about using high tensile as opposed to mild steel, and both 8.8 and 10.9 are high tensile. A mild steel nut, which are available cheaply, would be extremely dangerous in this application, or just about anywhere else on a car. A "property class 8" nut is matched to an 8.8 bolt and is ideal, a property class 10 nut is just wasted money, but can be used if it is what is available. A property class 5 nut should not be used on any mechanical or structural part, and is only marginally stronger than mild steel..
#11 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 07 February 2012 - 01:14 PM
Again you are referencing metric/ISO standards for strength relative to inch/SAE fasteners. Grade 5 will be nearly equivalent to ISO 8.8 and is not soft or buttery like "mild steel" Grade 2. Grade 8 has more alloy content for toughness and is closer to 10.9.
Hardness and toughness are not equivalent. Hardness is not typically desired in a fastener (nut or bolt) as hardness typically equates to brittleness. What is desired is higher toughness. Toughness defined in its simplest explanation is the ability to absorb energy prior to failure. (I make no attempt here to provide the stress/strain definition here). The application guides I use in my work focus not on bolt failure (snapping) but thread pull out.
Regardless, from a geometry standpoint, fasteners theoretically develop their full strength in three threads. In practice, steel bolts in steel tapped holes develop acceptable industry standard strength in "one diameter". That is to say, if you have a 5/16" bolt, you will develop full thread strength in a tapped hole 5/16" deep. With aluminum, the hole depth is typically 1.5x the diameter.
Will a Grade 5 nut strip before a Grade 8 when subjected to equal high levels of torque? Yes... assuming the bolt does not fail first. Does it matter in this application? No. The steering joints are held into their respective arms by the taper lock of the components. The torque level applied to the nuts is typical of other bolted joints on the car. If you choose to use higher-strength nuts... fine. You are not hurting anything. However, you are not gaining anything either.
Edited by dklawson, 07 February 2012 - 01:15 PM.
#12 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 07 February 2012 - 05:01 PM
simple use the correct nut/bolt/screw for the job, a lot of stuff out there is chocolate spec engineering surpliers are the best place to get nuts and bolts of the correct grade/spec.
dave
#13 Wil_h
Wil_h
  • 3,244 posts
Posted 07 February 2012 - 05:58 PM
You all seem to be missing the point (except dk). The nut in this case has no strength requirements, the bolt is in shear and the thread is under no stress.
Sure, use the high tensile stuff, but in thus case it will not be a problem using lower spec nuts. It is a little anoying that there is so much doom-mongering in this thread, when there is no risk. It seems that the doom-mongers do not fully understand what is specifically being asked.
As it happens, you should use a 5/16 UNF bolt, and not an 8mm. The 8mm will rattle about a bit.
#14 tiger99
tiger99
  • 8,584 posts
Posted 07 February 2012 - 09:19 PM
Yes, and 8mm is useless, but so is a 5/16" unless it is torqued up correctly. The bolt may seem to be carrying all the load in double shear, but in practice it needs to be causing there to be friction between the tie rod fork and lower arm, so there is no fretting, which would cause rapid wear.
On safety critical parts, always use the correct nut and bolt, and torque them up correctly. The original designer knew what he was doing, but you and I do not necessarily have all the facts.
#15 Surfbluegarage
Surfbluegarage
    AKA mini_mad_daps
  • 1,547 posts
Posted 07 February 2012 - 09:36 PM
who'd of thought ay 14 posts on a tie bar bolt.... wow..... :whistling:
Edited by Surfbluegarage, 07 February 2012 - 09:36 PM.
