Desperately Need Help! Engine Still Not Running Properly After Full Rebuild!
20 replies to this topic
#16 bwi_bwi_12
bwi_bwi_12
  • 43 posts
  • Local Club: n/a
Posted 07 February 2012 - 05:44 PM
Well just because its not rich enough to burn doesn't mean there isn't fuel there at all and it has to go somewhere, it would get blown through and it would condense and pool. From what you've said I can't see what else might be wrong. Webbers and their manifolds are worse than the SU for port robbing yes, they are also bad for fuel condensation. That's why split Webbers were developed. They are also quite clunky carbs by comparison, quite fuel thirsty and unrefined. As I've said though I don't really get to have much to do with them, I expect in the hands of an expert they can be made to sing. Many people seem to love them, it's just I'm not one of them! Assuming you have just written the kPa results wrong here by a factor of 100 then yes, I'd say the compression is fine. Compression tests are a little pointless really in my opinion. They only ever tell you something you can already tell by other means or by elimination. But if you did a wet compression test you would probably find the small difference went away. But just in case, and for the sake of asking, have you gapped the plugs?
So, I ran the car around the block a couple of times and took out the plugs. Number 1 and 4 are lighter in colour with a slight mustard deposit on the ground electrode. The inner two cylinders are darker which I presume means the outer two cylinders are running lean while the inner ones are rich. Does this effect diminish as the revs increase of is it worse at higher revs compared to idle?
I re-measured my manifold... It is 4,5" not 5" as i was told. I reckon maybe I would be better with a longer one. What do you think? Will it improve the port robbing effect?
#17 bwi_bwi_12
bwi_bwi_12
  • 43 posts
  • Local Club: n/a
Posted 09 February 2012 - 02:35 PM
Twaddle.........
useful...
#18 bwi_bwi_12
bwi_bwi_12
  • 43 posts
  • Local Club: n/a
Posted 09 February 2012 - 03:41 PM
This mustard deposit on the plugs, is it like crusty/fine sand ? If it is it's burning oil........
I wouldnt say sand. Its just a sort of oxide deposit. Just a colouration.
#19 carbon
carbon
  • 2,590 posts
Posted 09 February 2012 - 07:58 PM
This spec is very similar to mine, which needs 10 degrees static advance to get decent tickover. Centrifugal advance is 10deg (20 at crank) but with heavier primary advance spring to stop pinking under load at low speeds. Also has vac advance fitted. Runs a treat on single 1.5SU.
#20 bwi_bwi_12
bwi_bwi_12
  • 43 posts
  • Local Club: n/a
Posted 10 February 2012 - 03:37 PM
Post a pic of all 4 plugs
here we go.
first one is number 1, second number 2, etc
Attached File  07022012773.jpg   80.26K   4 downloads
Attached File  07022012774.jpg   69.73K   4 downloads
Attached File  07022012775.jpg   72.52K   4 downloads
now maybe im being thick, but I cant seem to upload more pictures. This is silly. It says I have used up the 9.77MB global upload quota. hmmm
#21 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 10 February 2012 - 03:44 PM
You need to upload them to a host site like photobucket or flickr and then copy and paste the [ img ] code into the thread, it saves on our bandwidth then. :)
