where abouts is that fuse pal ?
Indicators Not Working
RossKnight
, Feb 08 2012 02:06 PM
36 replies to this topic
#31
Posted 09 February 2012 - 04:51 PM
#32
Posted 09 February 2012 - 05:13 PM
I have found with the in line fuse holders - especially the ones round the back of the carb - is that if a current is running though it long enough and a poor connection is present, then everything heats up and melts the plastic holder which in turn distorts and breaks the contact.
I have replaced the inline glass fuses with inline blade type holders.
The idea being, it is easier to see if the fuse has blown and , in theory, should be less problematic.
#33
Posted 09 February 2012 - 05:37 PM
orange wire with purple trace, behind the carb/airfilter, may be tucked under the scuttlewhere abouts is that fuse pal ?
Blade fuses are different ratings to glass fuses, did you use the correct blade fuses?I have replaced the inline glass fuses with inline blade type holders.
#34
Posted 09 February 2012 - 06:07 PM
Yep!!!
#35
Posted 15 February 2012 - 10:23 PM
Thanks bud, I'll have a root around under my scuttle !!
#36
Posted 15 February 2012 - 10:29 PM
Mine did the same thing.
It ended up being a inline fuse (behide air filter) had blown and melted the fuse holder had to replace the whole thing only a couple of quid and about 5 min job everything works fine now.
Hope you work it out :)
#37
Posted 16 February 2012 - 11:11 AM
Try pressing the hazard switch on for about two flashes and then turn off and then try your indicators
