Rattling Noise (When Brake Pedal Released)
7 replies to this topic
#1 MiniElliott
MiniElliott
  • 378 posts
Posted 08 February 2012 - 02:47 PM
Hi, Im not sure if this has been asked before but when my brake pedal is released their is a rattling sound coming from the engine bay. Ive only noticed today that when I depress the brake pedal the rattle stops. I must mention the car runs fine and has no braking issuse and I carnt see any thing obvious.
What could this be ?
By the way its a 1978 Mini 1000 with no mods if this helps
Hopefully you can see and hear in the video what happens
Any help is appreciated
Elliott
Edited by MiniElliott, 08 February 2012 - 02:55 PM.
#2 Msmith3327
Msmith3327
  • 220 posts
  • Local Club: Torbay Mini Club
Posted 08 February 2012 - 03:02 PM
This may not be it but have you checked the water shroud thingys on the hubs!
#3 JonnyBMX
JonnyBMX
  • 865 posts
  • Local Club: Rebels
Posted 08 February 2012 - 03:03 PM
are all the engine mounts okay?
#4 thebullet
thebullet
  • 1,337 posts
Posted 08 February 2012 - 03:06 PM
What happens when you put your foot on the clutch?
#5 reallybig
reallybig
  • 613 posts
Posted 08 February 2012 - 03:13 PM
messy floor :D
checked to see if the break master cylinder is secured?
checked the break calipers themselves?
#6 greenwheels
greenwheels
  • 689 posts
  • Local Club: Mini Fixers
Posted 08 February 2012 - 03:17 PM
Something is resonating which stops when you pressurise the brake system and "stiffen it up". Check everything in the pipework / cylinder system is secure and the bracketry holding it to the body is not corroded.
#7 callumwebber
callumwebber
  • 90 posts
Posted 26 November 2013 - 09:45 PM
did you find out what it was? i have the same thing cheers
#8 MiniElliott
MiniElliott
  • 378 posts
Posted 11 December 2013 - 07:14 PM
Hi, i never found the problem, it just disappeared. However i'm fairly certain it was one of the brake pipes hitting the bulkhead when pressurized.
