Best Sound Proofing Material
Posted 09 February 2012 - 03:11 PM
What would you recommend using to make my mini quiter.
I have seen some people use dynamat and other expensive materials but wasnt sure if there was a cheaper option.
Dan
Posted 09 February 2012 - 03:13 PM
Posted 09 February 2012 - 04:14 PM
brown bread
http://www.brownbread.eng.net/
That sound DEADENING not insulation.
Deadening stops rattling, sound insulation stops noise, like road noise.
Ideally you want to deaden and insulate a mini.
Silent coat is a good sound deadening, I've used it on my mini and it stopped alot of rattles and blocked out a little road noise. you can get 2mm stuff and 4mm. I put 2mm stuff behind door cards and 4mm everywhere else.
For sound deadening you can use things like carpet underlay, stuff like cloud9 is supposed to be good. Or you can use proper closed cell foam which is better. silent coat do a closed cell foam which is good for sound insulation.
There is one called Second skin luxury liner pro. this has a layer of closed cell foam, and a layer of this think liner stuff. this is supposed to be the best for sound insulation in a car.
Posted 09 February 2012 - 06:19 PM
Posted 09 February 2012 - 06:49 PM
Posted 09 February 2012 - 07:05 PM
brown bread
Promoted as sound deadening.....works very well in both aspects..... You tried the stuff? It is very good
OP specifically referred to dynamat, and this is widely considered to be a solid alternative at better cost.
Posted 09 February 2012 - 11:19 PM
Thank you very much. i will have a look at them all.
Just wanted to make my mini quieter
Posted 10 February 2012 - 10:19 AM
brown bread
I found that dynamat is actually more expensive, and silent coat worked just as good. But each to there own n all that :)
Posted 22 March 2012 - 12:29 PM
Thanks for the info on the samples of the Silent coat stuff, will get myself afew sheets. Just wish ide thought about it before i fitted my dash back in.
Posted 23 March 2012 - 03:59 PM
Saw this topic a while ago and as ive just fitted a weber im considering putting some sound proofing against the bulkhead to try and keep some noise out.
It would help to put more sound insulation, as silent coat stops rattles and vibration, its a sound deadening material.
Posted 23 March 2012 - 04:00 PM
Ahh i see, sorry i must not have read this topic properly.
I will look into it, thanks
Posted 23 March 2012 - 04:11 PM
