Posted 10 February 2012 - 10:39 PM
Where have you found any jets with a plastic nut? The ones sold by both Mini Spares and Mini Sport are genuine AFAIK. They aren't braided, they have a steel spring protecting the Nylon fuel hose and a brass tube nut with sealing washers.
There are indeed different colour coded jets for SU HS carbs, and many small niggling problems with the setup of SU carbs are caused by people assuming that they don't need to change the jet (and other details) when moving a carb from another car or building a pair from singles. Jets (like carb bodies) are handed, so no you can't just use two Mini single carb jets. The tube connects to the base of the jet at an angle from the linkage, the left and right carbs are the mirror of each other so a left carb body need a left jet and vice versa. SU call them front and rear rather than left and right because everything is named based on an inline engine (same as the cylinders, front plate, back plate etc). The jets for singles are a different length, I believe they are longer but I'm not certain I'm remembering that right, but they are different. I understand it's because the singles and twins have different amounts of choke travel, goverened by the jet rod and the choke lever. If you setup the wrong length of jet with a given choke lever and jet rod the jet will never be at the proper position. There are also two different bores of jet, but all Minis use the same size. SUs are all about the jet and needle relationship under a given amount of manifold depression and it's all designed into the physical parts so you have to get the right parts for the application. Having said that, you don't choose jets based on the exact engine tuning, as Roy says that's what the needle is for. You choose jets based on the broad application, you just need a pair of twin carb jets for a Mini. They are a green and a pink.
