Drain On Battery
Posted 12 February 2012 - 02:37 PM
I have a 1999 MPI mini cooper. I am having problems with battery drain when the car is not used daily. I have had the alternator and battery checked out at my local garage and checked them myself and both are good. With the engine running I get around 14.15 volts at the battery. The battery is only about a month old and this problem was there before the battery was replaced.
I have been checking the battery voltage for the last 2 nights. The first night I left the battery connected and the reading last thing was 12.64 volts, the following morning this had dropped to 12.19 volts.
The following night I did the same check, but removed the battery earth lead over night. The readings were 12.85 volts in the evening and 12.67 volts this morning.
I have used a meter to check the battery drain and this appears to be a constant 140mA. I have then checked every fuse one at a time and the only drain i could find was connected to the alarm, radio and clock (C4) and this only measured around 9mA. I have removed all the fuses from the inside fuse box and still read a drain at the battery of 130mA.
Does anyone have any suggestions where or what to try next?
Posted 12 February 2012 - 03:05 PM
Posted 12 February 2012 - 04:59 PM
maybe the multi plugs by the steering coulomb
Posted 12 February 2012 - 05:42 PM
Posted 12 February 2012 - 07:52 PM
Posted 12 February 2012 - 08:56 PM
Posted 16 February 2012 - 10:35 PM
Posted 17 February 2012 - 11:08 AM
Posted 17 February 2012 - 01:43 PM
But as has been said, the alternator is always in circuit, and could have a leaky diode.
Posted 17 February 2012 - 05:18 PM
Good call! Some cars have been found to hold the main relay on after the engine is shut down. Can't remember wht the real reason was, but its deep in the injection section somewhere.
Well it happened to me but it is a SPI. It was resolved with a remanufactured ECU. Long story:
http://www.theminiforum.co.uk/forums/topic/119357-ecu-smart-failure/
Posted 17 February 2012 - 08:24 PM
Posted 18 February 2012 - 10:16 AM
Posted 22 February 2012 - 07:15 PM
Posted 21 March 2012 - 10:53 PM
Posted 21 March 2012 - 11:08 PM
disconnected the wire between the battery and car body
now fit the multi meter between the negative terminal on the battery and the earth point on the body
