Compile A List Of Parts Idea....
Posted 12 February 2012 - 05:57 PM
Would it be possible to pull together and for the sake of new users compile a list of nesessary parts and web links to the said parts. So we can have a section in this thread for subframes
for example
pedal boxes (OPTIONAL)
"INSERT WEB SITES HERE"
aftermarket fuel components (OPTIONAL)
subframes (REQUIRED)
Thats the type of layout im looking for. Do you think we could do somthing like this?
We could make it a "Stickey" and it would be a good resource for new users and make the whole process less daunting for the newcomer. Let me know what you think?
Regards, Tom.
Posted 12 February 2012 - 06:11 PM
I have been looking at Vtec'ing my Mini for a while. Although I have a engineering background its not with cars. I could probably put the jigsaw puzzle together after I have all the bits, but I dont know 100% whats needed.
for example
http://superfastmini...%20PRODUCTS.htm
they have all the subframes for the honda engines, other people might know if they are any good, never used them myself tho
Regards, Tom.
Edited by scubalegg, 12 February 2012 - 06:11 PM.
Posted 12 February 2012 - 06:23 PM
Edited by mrthumb, 12 February 2012 - 06:24 PM.
Posted 12 February 2012 - 06:58 PM
Posted 13 February 2012 - 11:08 AM
Watsons (UK)
http://www.watsonsrally.co.uk/
This company has the most experience in fitting VTEC's to mini's. Initially developed for rallying application, frame based upon Metro subframe which increases track and requires a clubman or extended round nose.
Allspeed Engineering (UK)
http://www.allspeede...m/subframes.htm
Allspeed can supply a kit to fit a VTEC, 2.0 or 1.6 Vauxhall engine into your mini, the frames are completely custom built and customers always have positive things to say about this company.
Posted 13 February 2012 - 11:07 PM
Seven frames are available, the first five will fit standard round nose
Mini track & Suspension setup & will fit standard round nose
1) Allspeed - www.allspeedengineering.com
2) Ringmini.de www.ringmini.de (LHD due to rack issues)
3) American Frames - Brian Campbell
4) American Frames - S Alexander[banned from forum due to abuse] (LHD only)
5) American Frames - Minitec http://www.superfastminis.com/
Frames 5b to 7 require lengthen fronts or Clubman front
5b) American Frames - Minitec old frame http://www.superfastminis.com/
Metro Track/Brakes & supsension
6) Watsons http://www.watsonsrally.co.uk
7) P&L http://www.plmini.co.uk
Metro Track & mini brakes
8 ) SAE http://www.saeminivtec.co.uk
Work in Progress Frames
AMT No Longer producing frames. Please do not contact them.
Streetfighter (work in progress)
Ask Restorations Vtec frame (work in progress) phone 01955 641450
Below are some details of completed frames:-
1) Allspeed (Mini Brakes/Supsension and track & standard round nose)
2) Ringmini (Mini brakes/supsension and track & standard round nose) LHD only[rack issues]
3) Brian Campbell (Mini Brakes/Supsension and track & Standard round nose)
4) Mintec (mini wheel stud pattern, mini track, mini brakes)
5)Watsons (k series wheels or 100 PCD stud pattern large selection, wider track but better K series suspsension)
6) 6) P & L Minis (k series wheels on front and mini on back? and the engine mounts only allows for certain b16 engines eg. 96 CRX, you need to check with P & L over this before buying your engine/frame)
7) SAE (mini wheel stud pattern/brakes/suspension; if standard inlet used, bulkhead needs cutting, K series track)
8 ) S Alexander (Mini Brakes/Supsension and track & Standard round nose) LHD only[rack issues]
Allspeeds frame, Ringmini, S Alexander and Brian Campbells frame keep the same track. They all fit into LHD standard round nose front, Allspeed will also fit RHD but will require a revised exhaust manifold to fit into standard round nose. There will be issues with the inlet manifold clearance and alternator on both BC and Allspeeds frame. Ringmini & Brian Campbells and S Alexander also has issues with the Diff housing hitting the steering rack for RHD. For standard round nose, you will need custom radiators.
Number 5, 6 & 7 on the list above are based around the k series frame and therefore increase the track of the vehicle. As a result you will have to be careful with wheel selection to ensure they fit under sportspack arches(see other discussions on this point).
The normal rear subframe can be used with any of the above, but spacers(not in the normal sense of spacers) have to be fitted - slightly different depending on 5,6 or 7 above, they are however supplied as part of the kit.
Any other questions please make a separate posting and we will try to help
DarrenW
From http://www.16vminicl...read.php?t=2742
