- MINI A SERIES THICK FLANGE BLOCK (NOT A +) 11 STUD CONVERSION, 74MM BORE, HONED,
- M.E.D 84.0MM LONG STROKE TUFTRIDED CRANKSHAFT, CROSS DRILLED & BACK DRILLED + GROUND TO COOPER S AEG 625 CONROD JOURNALS
- 12G940 11 STUD LATE TURBO CYLINDER HEAD, PORTED & POLISHED, FRESHLY SKIMMED & LAPPED.
- KENT MD276 FAST ROAD / RALLY CAMSHAFT POWER RANGE 1500-7000RPM.
- COOPER S AEG625 CONROD SET
- 74MM OMEGA DISHED PISTON SET 16CC DISH
- OMEGA LIGHT WEIGHT GUDGEON PINS X 4
- LIGHTENED & POLISHED DISTRIBUTOR DRIVE
- NEW BIG END BEARINGS SHELLS
- NEW MAIN BEARING SHELLS
- NEW CRANKSHAFT THRUST WASHERS
- NEW CAMSHAFT BEARING SET
- NEW CORE PLUGS
- NEW OIL PUMP
- NEW ALLOY WATER PUMP
- NEW A+ DUPLEX TIMING GEAR + TENSIONER
- NEW OIL PRESSURE SWITCH
- NEW OIL PRESSURE VALVE SPRING
- NEW WATER TEMPERATURE SENSOR
- NEW VERTO TYPE CLUTCH PLATE & PRESSURE PLATE
- NEW OIL FILTER
- NEW GASKETS & SEALS THROUGHOUT ENGINE
- CAM FOLLOWER SET, ROCKER ASSEMBLY
- VERTO FLYWHEEL, BELL HOUSING, END COVER, PUSHROD SET
- 4 SYNCRO 4 SPEED ROD CHANGE GEARBOX
- 2.9 RATIO DIFF, CENTRE OIL PICK-UP
- ALLOY HIGH LIFT ROCKER COVER 11 STUD
- TIMING COVER, CRANKSHAFT DAMPER, OIL FILTER HOUSING
- 1275 A+ TRANSFER GEAR SET
PM FOR ANYMORE INFORMATION YOU MIGHT REQUIRE. MORE ENGINES AVAILABLE.
Edited by l05bhpmini, 13 February 2012 - 06:43 PM.
