Hello,
Quick question to the people with a standard SPI engine/gearbox.
How many rpm does your engine run at which speed?
I fitted an other gearbox (probably with 3.44 diff) and I run 3000 rpm at 80 km/h (50 mph)
And when I asked a friend with an SPI, he does the same rpm for the same speed, but I always thought the SPI had an 3.1 final drive, so normally his rpm should be lower...
Anyone to compare with.
Thanks,
Dieter
Rpm/speed? [Spi]
dieter1310
, Feb 13 2012 08:01 PM
3 replies to this topic
Posted 13 February 2012 - 08:01 PM
Posted 13 February 2012 - 08:04 PM
at 70mph mine sits just above 4000 ive got a stage one fitted.
Posted 13 February 2012 - 11:53 PM
Check out Guessworks ratio calculator. It might help you out:
http://www.guess-wor.../Tech/ratio.htm
Posted 17 February 2012 - 10:08 PM
thanks
Will take a look at this site.
