Removing Front Upper Suspension Arm
Posted 15 February 2012 - 04:45 PM
I've bought 4 new rubber springs and thought it was going to be pretty straight forward to fit them (as it was when I fitted my Hi Los), however I didn't realise that I needed to remove the front upper suspension arms in order to get the rubber springs out/in. The problem is I can't see how to get access to the front bolt holding each arm, whilst the engine still in place!
Any advice would be greatly appreciated!
Thanks,
Phill
Posted 15 February 2012 - 05:06 PM
Posted 15 February 2012 - 06:33 PM
Posted 15 February 2012 - 10:40 PM
Always have a close look. If your eyeball says there is room to do something in situ, and your fingers seem to be small enough, give it a go.
Posted 16 February 2012 - 12:51 AM
Posted 16 February 2012 - 10:01 AM
Posted 16 February 2012 - 10:14 AM
The engine doesn't have to come out to do either of those jobs, in fact to change the passenger side top arm you don't even have to open the bonnet really. There is an access window in the flitch under the rad that is there specifically to access the top arm fixings and brake lines without pulling the rad.
Posted 16 February 2012 - 10:59 AM
I had decided my engine was going to come out prior to doing the passenger side cone due to the change of steering rack and I also wanted to give it a lick of paint at the same time. If your a dab hand (as you must be) I would imagine you could do it without moving the rad. Two of the more fustrating jobs on a mini (steering rack and cones).The engine doesn't have to come out to do either of those jobs, in fact to change the passenger side top arm you don't even have to open the bonnet really. There is an access window in the flitch under the rad that is there specifically to access the top arm fixings and brake lines without pulling the rad.
Sorry to thread jack... :-(
Edited by rendersonique, 16 February 2012 - 11:00 AM.
Posted 16 February 2012 - 11:13 AM
Posted 17 February 2012 - 12:28 AM
Posted 17 February 2012 - 12:43 AM
Posted 02 December 2017 - 12:39 PM
Help please.
I have the submarine out so I would have thought easy life. Ooops forgot its a Mini I'm working on.
I have undone all the bolts plates etc and driven the pivot bar out towards the front. I just want to be sure that is correct as it does not seem to want to move much more. I presume I just have to hit it harder. Is that correct
Posted 02 December 2017 - 03:00 PM
So I managed to get upper arms out but now am stuck trying to remove the old bearings. so far not much luck, any bright ideas?
Posted 02 December 2017 - 03:08 PM
Edited by Swift_General, 02 December 2017 - 06:07 PM.
