Hi guys, what is the best way to lift the car to remove the front and rear subframes? i have already removed the engine.
many thanks,
stu
Jacking The Car For Subframe Removal
Stu
, Feb 18 2012 07:06 PM
4 replies to this topic
Posted 18 February 2012 - 07:06 PM
Posted 18 February 2012 - 07:25 PM
Couple of mates. One each corner. Lift over subframe and roll it out
Posted 18 February 2012 - 07:35 PM
Get some good strong planking, scaffold plank is ideal. put it under the car from side to side under the front floor pan, and at the rear just foreward of where the subframe mounts. Then use axle stands under the planks.
I've got a trolley jack with a high lift on it that I put under the subframe to lift the car then put the planks in place like mentioned.
Posted 18 February 2012 - 08:01 PM
pallets, stack of three screwed together.
Posted 18 February 2012 - 08:04 PM
As above I used 2 planks as far forward/back as possible with axle stands underneath. Watch out for fuel/brake pipes though. I was replacing mine so it didn't matter.
(null)
(null)
