Honda Clocks
4 replies to this topic
#1 david@skeggyminis
david@skeggyminis
  • 352 posts
Posted 19 February 2012 - 07:30 PM
Hi does anyone know if the civic clocks are interchangable between years of manufacture i need clocks to fit a '94 d16z6 vtec engine id like to use '99-'00 clocks but dnt know if they will work can anyone help?
#2 Andykettle
Andykettle
  • 174 posts
  • Local Club: GR8 MINIS!
Posted 20 February 2012 - 09:10 PM
Yes they should be. You can fit later 2001 EP3 civic clocks and even S2000 digital dash with a bit of a re-wire.
Look on http://www.hondacivicforum.co.uk/ for people braking cars or put a wanted post.
#3 79 clubby
79 clubby
  • 165 posts
  • Local Club: .
Posted 21 February 2012 - 08:57 AM
i have a 2000 civic i am breaking pm with what you are looking for.
#4 david@skeggyminis
david@skeggyminis
  • 352 posts
Posted 22 February 2012 - 04:24 PM
hi mate thanks im after the speedo cluster with rev counted and petrol/temp gauge
#5 TypeR_Mini
TypeR_Mini
  • 41 posts
Posted 29 February 2012 - 10:45 PM
You would need the 99-00 cluster with harness clips (pigtails) and circuit schematics for both the vehicle your engine is from as well as the one for the year cluster you are using in order to wire things up. If you choose to go with the s2000 digital setup, a speedo heal kit will be required to adapt the speedo signals. http://honda-tech.co...d.php?t=2612122 << great honda resource for us DIY guys. hope this helps!
