Any advice would be very much appreciated
Posted 20 February 2012 - 10:30 PM
Posted 20 February 2012 - 10:33 PM
Posted 20 February 2012 - 10:50 PM
Posted 20 February 2012 - 11:09 PM
Posted 20 February 2012 - 11:22 PM
Posted 21 February 2012 - 04:11 PM
Posted 21 February 2012 - 04:30 PM
Posted 21 February 2012 - 05:07 PM
Posted 21 February 2012 - 05:23 PM
Ok well this is just my opinion, but there is no point going for a 1380 in your case unless you've already had the block work done. 1380's are really only the way forward when your trying to get the absolute maximum power out of an engine or planning on running a racey cam, where the extra CC's will help pull the engine when it is off cam. You end up spending more money on a 1380 for a very small gain, and once the bores are worn - Thats it, the block is scrap.
If you stick to a standard rebore such as 1293, you can extend the life of the block massively as it can be still be rebored again and again when required. Remember 1275 blocks aren't being made any more and are getting harder to come by at a decent price. Of course people will say, its you engine do what you want, which is right; but future block life is worth keeping in mind.
Opinion aside, the type of engine you want is similar to what I wanted when I built my engine.
My spec is as follows:
Rebuilt 1275
Stage 3 head - 35.5mm inlets, 29mm exhausts, 185lb double valve springs and a load of porting work.
Morspeed phase 3 cam - Similar to a Kent 276. You could go for a 286, but this would be quite lairy and not give you decent power till around 3000rpm
Kent vernier timing gears
Pre verto clutch, orange clutch cover, AP bonded rally clutch plate, ultralight flywheel
LCB manifold, RC40 exhaust
HIF44 carb, alloy inlet, K&N cone filter
Megajolt mappable ignition - A must for any A series in my opinion.
So far its not been driven but it run nice, idle's not too lumpy at 1000rpm and should pull from around 2000rpm. I'm hoping it'll make close to 85-90bhp.
Edited by oltonlad, 21 February 2012 - 05:37 PM.
Posted 21 February 2012 - 05:34 PM
Posted 21 February 2012 - 05:38 PM
Posted 21 February 2012 - 05:39 PM
Posted 21 February 2012 - 06:29 PM
Posted 21 February 2012 - 06:43 PM
Posted 21 February 2012 - 07:13 PM
