Cr Help :)
11 replies to this topic
#1 coopdog
coopdog
  • 4,506 posts
Posted 21 February 2012 - 10:20 PM
Well I'm just thinking about doing some stuff, main thing is doing the head, I'm getting a 12g295 head for my 998 running unskimmed which will give me about a cr of 9:3:1 how would this run and how much hp would I lose compare to having it skimmed to 10cr
#2 ACDodd
ACDodd
  • Mini Docs
  • 2,767 posts
Posted 22 February 2012 - 12:01 AM
Not much at all actually about 1%. Across the rev range, more importantly what cam are you running?
AC
#3 coopdog
coopdog
  • 4,506 posts
Posted 22 February 2012 - 10:32 AM
AC
was running a standard cam atm, but will be using a mg metro cam
#4 ACDodd
ACDodd
  • Mini Docs
  • 2,767 posts
Posted 22 February 2012 - 08:42 PM
Leave it as is. The engine will be less fussy an longer lived. Just set it up properly and ensure that the valves seal well and the timng and fueling are correct.
AC
#5 racingenglishcars
racingenglishcars
  • 293 posts
  • Local Club: Donn's Backyard Garage
Posted 23 February 2012 - 08:34 AM
I calculate CR=8.3 with unskimmed 12G295 head (28.3cc), 1mm head gasket (3.43cc), 0.7mm deck height (2.29cc) and 0.25mm ring land (0.32cc). This assumes no overbore and swept volume 249.1cc. Am I missing something or do you have another way of calculating CR?
Edited by racingenglishcars, 23 February 2012 - 08:45 AM.
#6 mini_in_progress
mini_in_progress
  • 641 posts
Posted 23 February 2012 - 11:16 AM
stick a turbo on it :D
#7 coopdog
coopdog
  • 4,506 posts
Posted 23 February 2012 - 12:18 PM
thats the plan :)
i got told thats how much it will be if i put the head on :/
#8 coopdog
coopdog
  • 4,506 posts
Posted 23 February 2012 - 12:23 PM
is this with flat top pistons?
#9 Wil_h
Wil_h
  • 3,244 posts
Posted 23 February 2012 - 01:57 PM
9.3:1 is closer than 8.3:1. Gasket is 2.8cc not 3.4cc. Not sure where you get the deck height from? You'd need to measure the engine I guess, but typically I use 0, which is what all the 998s I have are; I've never seen 0.7mm or even close to it.
There is nothing wrong with your calculation, just the assumptions you have made.
#10 racingenglishcars
racingenglishcars
  • 293 posts
Posted 23 February 2012 - 04:44 PM
OK by me, let's assume 0 deck, head gasket 2.8cc (~0.82 thick) non-skimmed 295 head, flattops and no ring land gives closer to 9:1 cr. :)
#11 Wil_h
Wil_h
  • 3,244 posts
Posted 23 February 2012 - 06:47 PM
Sounds good to me. I dug an old figure out of my head. Having now checked, 9.3:1 was for a +40 998
#12 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 23 February 2012 - 09:24 PM
I built a 998 with +0.020" Minispares flat tops & they sat just over 0.040" down the bore at TDC so it's essential to check.
Phil.
