What Width Are My Wheels?
9 replies to this topic
#1 markperkin
markperkin
  • 37 posts
Posted 22 February 2012 - 11:48 AM
Hi, sorry to ask what may seem a stupid question, but i have a set of 10" mamba's and i'm not sure where i measure to get the width of the wheel. Any help would be great thanks.
#2 MiniMadNox
MiniMadNox
    Previously known as minimad1992
  • 266 posts
Posted 22 February 2012 - 01:17 PM
You can get it from the tyre usually.
#3 markperkin
markperkin
  • 37 posts
Posted 22 February 2012 - 01:21 PM
They have no tyres on, although my car currently has 12" wheels which appear to be the same width and i'm not at home to check tyre size.
#4 MiniMadNox
MiniMadNox
  • 266 posts
Posted 22 February 2012 - 01:25 PM
Measure the width of the wheel?
#5 markperkin
markperkin
  • 37 posts
Posted 22 February 2012 - 01:27 PM
From what part of the wheel though?
#6 Minuki
Minuki
  • 186 posts
Posted 22 February 2012 - 02:02 PM
Mamba's are usually 10x6. Measure from edge to edge.
#7 markperkin
markperkin
  • 37 posts
Posted 22 February 2012 - 02:38 PM
Ok, is it inside edge of both sides of the rim i measure between?
#8 AVV IT
AVV IT
    I am a shed dragger.
  • 6,122 posts
  • Name: Dave
Posted 22 February 2012 - 02:46 PM
It's the distance between the inner edges of the rim, where the bead of the tyre wall would sit against. So basically it's the space that the tyre itself sits within on the wheel. It's a common misconception that rim width is actually the overall width of the wheel, when depending upon the style of the wheel this is usually at least half an inch bigger. This is why so many people measure standard Rover mini 12" wheels as 5", when in fact they are actually 4.5" rims.
The tyre gives you dimensions of the tyre, not the wheel itself. Tyres of a certain width can be fitted to a variety of different width wheels. Some tyres may display a maximum rim width or a specific rim width range, but this will not tell you which rim width that particular tyre has been fitted to. For instance the common 165/60/12 classic mini tyre is fitted to a variety of 12" wheels with rim widths between 4.5" - 5.5".
Edited by AVV IT, 22 February 2012 - 02:54 PM.
#9 markperkin
markperkin
  • 37 posts
Posted 22 February 2012 - 02:49 PM
That's great, thanks for all the help, will measure them when i get home.
#10 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 22 February 2012 - 04:58 PM
http://www.carbibles...tyre_bible.html
