I have two cams that Im not going to use due to going for a turbo.
First an AEG 649, oil pump Spider drive, no mechanical fuel pump bit, cam lobes are wider than I have seen on most? I have been informed that they were fitted to the 970 and 1071 coopers? It is meant for a mini without a mechanical fuel pump though. It looks in good overall condition, bearing surfaces are all good, one small speck of rust on the bearing surface close to the oil pump drive on the out side edge, will prob polish up fine, see pics lobes all look ok few very small marks on one or two.
Second is a Kent cams 731, oil pump slot drive and with the mechanical fuel pump bit. Not sure if this one is useable as the bearing surfaces are pitted (see photos) The lobes are all very good, there is also a small chip out of the dizzy drive, however I don't think that would affect it at all.
no idea of value or use.
Camshafts Value One 731 And One 649
Nic
, Feb 22 2012 04:50 PM
No replies to this topic
