Why Cant I Adjust The Mixture On My Carb
Posted 22 February 2012 - 07:31 PM
it doesnt make any differance
The spark plugs are really sooty and after cleaning become like this after a couple of miutes of running
The choke is fully off and also checked the choke cam it as returned to its home position with the accelorator cam having about 0.5mm clearance on its fast idle bolt.
i thought it was screw in to richen mixture and out to lean it but when doing this it doesnt make any differance
its a 1275cc A+ with electric dizzy it As a BDL needle which i was advised to fit for a good starting point
Any ideas
Posted 22 February 2012 - 07:52 PM
Posted 22 February 2012 - 08:00 PM
Posted 22 February 2012 - 08:34 PM
james.
Posted 22 February 2012 - 08:40 PM
my problem when im addusting the screw it doesnt seem to be making a differance
Posted 22 February 2012 - 08:52 PM
Somtimes the jet can be free'd off by gently pushing on the jet tube with a screwdriver. Be careful not to damage it. Turn the mixture screw up and down to see if the jet then moves.
But you may have to delve deeper. The best way to doo this is get a service kit and clean out the float bowl, change the jet, re set the float level fit a new seal and refit the car. If you do have to goo this far consider a full overhaul.
AC
Edited by ACDodd, 22 February 2012 - 08:56 PM.
Posted 22 February 2012 - 08:58 PM
Posted 22 February 2012 - 09:01 PM
AC
Posted 22 February 2012 - 09:07 PM
I bought the carb second hand so i think someone as rebuilt it and just tightened it upand not reset it. probably makes sense.
or have i talked myself into it
Posted 22 February 2012 - 09:29 PM
Just like other people said - find a nice rebuild manual (I think that Haynes Book of lies covers this part very well), order a rebuild kit and give it a try. SU carbs are not that complicated to rebuild, given that you take some care and attention. Otherwise, get (pay) someone else to do it.
Posted 22 February 2012 - 09:31 PM
Posted 23 February 2012 - 11:08 AM
If, when turning the adjustment screw, the jet doesn't move, then, you'll have to investigate in the float chamber, as I said before.
Edited by jon_dec, 23 February 2012 - 11:10 AM.
