Float Needle Problems
15 replies to this topic
#1 sam138
sam138
  • 509 posts
Posted 26 February 2012 - 02:56 PM
Had my car check by a mate who told me I need a new float needle valve as the old kept sticking and causing overflow to drip petrol. I went to minispares and showed them the carb I am running and they gave me a needle kit . I now have replaced the float needle but is still
leaking fuel but runs, with the odd occasion of stalling ? Anyone know what could be wrong . Sam
#2 sam138
sam138
  • 509 posts
Posted 26 February 2012 - 03:26 PM
It's a 1992 998cc running a hif 38 carb I have been told by minispares . Could it be the size of the needle is diffrent . As the new
one is a rubber tip the old one was a metal tip?
#3 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 26 February 2012 - 03:54 PM
Replacing the needle and seat is one task. When you installed the parts there are also some float adjustments that need to be made. I don't work much with HIF carbs so others will have to tell you how to adjust the float height. Generally though the Viton (rubber) tipped needles work well, frequently better than the metal tipped valve.
#4 sam138
sam138
  • 509 posts
Posted 26 February 2012 - 04:12 PM
many thanks for your help i'll have a search around the internet on how to adjust the float .
#5 sam138
sam138
  • 509 posts
Posted 26 February 2012 - 04:28 PM
http://www.minispare....aspx?pid=37616 this is the float kit that was purchased but am having doubts about if its the right one they gave me .
#6 ACDodd
ACDodd
  • Mini Docs
  • 2,767 posts
Posted 26 February 2012 - 04:53 PM
Thats a float needle kit for a HS type carb not the HIF type. As a rebuild tip, always use the old seating and fit the new needle. I have found the new seats are not usually machined correctly. The result is you get a better seal using the old seat and new needle. Set the float as per your workshop manual.
AC
#7 sam138
sam138
  • 509 posts
Posted 26 February 2012 - 05:02 PM
this is the carb i am running is this a hif 38 and is their a way i could adjust the needle to suit .
#8 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 26 February 2012 - 05:03 PM
EDITED:
If you have and HIF carb the float valve you need is in the kit linked below.
http://www.minispare...id=38178&title=
(Mini Spares Item WZX1095)
From the picture you posted it looks like you do have an HS series carb and what you bought should work. You will need to adjust the float height though. If you have the all plastic float that means using stacked fiber washers to move the float valve up or down as needed.
Edited by dklawson, 26 February 2012 - 05:05 PM.
#9 sam138
sam138
  • 509 posts
Posted 26 February 2012 - 05:19 PM
many thanks for that and yes i have a yellow plastic float and do i need to unscrew the brass fitting which the needle sits in and add washers to this ? do you know what size washers they are ??
Many thanks sam
#10 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 26 February 2012 - 05:29 PM
Sorry... I don't know the washer size. Frankly on carbs using the later floats I have frequently had to make my own washers out of gasket paper. As a rule though the new needle should come with a new fiber washer and I always save old ones to re-use when necessary.
#11 sam138
sam138
  • 509 posts
Posted 26 February 2012 - 05:33 PM
ok many thanks for your help the old brass fitting did not have a washer fitted and the new kit does not come with a washer so looks like i will have to make some . So if the float is overflow would i need a lot of washers roughly .
Sam
#12 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 26 February 2012 - 05:41 PM
Adding washers will "lower" the point at which the valve closes and that will help prevent flooding and overflow. I cannot predict how many you will need. You can get a general idea by referring to your manual. It will tell you how "high" the float needs to sit above the lid when the valve is properly adjusted. Knowing that, unscrew the brass seat from the lid until the adjustment is reached. Then look at the gap between the body of the brass seat and the bowl lid. That gap is how thick your stack of washers needs to be.
#13 jase350
jase350
  • 26 posts
Posted 26 February 2012 - 05:44 PM
Hi just replaeced the float valve on my 92/93 998cc mini and used the kit as per pic i have a su carb looks like the one you have too. Kit should work fine
#14 ACDodd
ACDodd
  • Mini Docs
  • 2,767 posts
Posted 26 February 2012 - 06:36 PM
Washers are not used to set the float height on an HIF carb, this is completed by adjusting the float arm which operates the needle valve.
AC
#15 sam138
sam138
  • 509 posts
Posted 26 February 2012 - 07:18 PM
many thanks for your help i will give some fibre washers a try tommorw :D
Sam
