Any Reason I Shouldn't Use This Oil - 20 50W (Acea A2/b2, Api Sj/cf)
21 replies to this topic
#1 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 26 February 2012 - 09:57 PM
I have trouble finding a reasonably priced oil over here in Sweden.
Have found the castrol classic - about 70 quid for 5 litres. Or Quaker 20 50w at roughly the same price.
However a chain over here (lets name them Swedish Halfords) do a 20 50 W mineral oil for 20 quid (5 litres). I am not sure what all the specification numbers mean, maybe someone does?
#2 govig
govig
  • 339 posts
Posted 26 February 2012 - 10:43 PM
The first two letters are the petrol engine spec and the last two diesel so A2 and SJ are the only relevant ones. Have a look at this to explain http://www.driverste....co.uk/oils.htm
It will be fine. Just change it regularly 5000 km max between changes. Avoid synthetics and semi-synthetics or oils thinner than 20W50 (15W50 ok though)
Edited by govig, 26 February 2012 - 10:45 PM.
#3 bmcecosse
bmcecosse
  • 9,699 posts
Posted 27 February 2012 - 12:09 AM
Yes - it will be fine - but still ubber expensive !
#4 brad-the-bear
brad-the-bear
  • 1,114 posts
Posted 27 February 2012 - 12:29 AM
look at some 10w/40 oil should be cheaper but still good enough for the engine, i use it in mine and morris lubricants advise 10w/40 too :D
#5 Cooperman
  • 23,293 posts
Posted 27 February 2012 - 01:26 PM
Always use a 20w50 of a really good quality in the UK. Change it often, max 3000 miles between changes.
#6 ian2000t
ian2000t
  • 111 posts
  • Local Club: Splinters Mini Club
Posted 27 February 2012 - 04:11 PM
I'd never use 10/40 in a Mini. When I first bought mine I started topping it up with Castrol GTX 10W/40 after following the Rover book. From that point on the oil pressure got less and less and it started burning more and more oil.
20W/50 all the way..
#7 reallybig
reallybig
  • 613 posts
Posted 27 February 2012 - 04:31 PM
hells yes
oh and if the oil actually stays in the engine, every 3k seems too often, didn't change the oil in mine for 40k and it wasn't that bad.
Edited by reallybig, 27 February 2012 - 04:33 PM.
#8 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 27 February 2012 - 04:38 PM
You have to remember that the average ambient temperature in Sweden is a little different to out 'moderate' climate in the UK.
Personally I'd be running 10/40 rather than 20/50.
#9 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 27 February 2012 - 06:11 PM
Thanks guys!
Last change I used 15 50 as I couldn't put my hands on 20 50. Previous to that i used 10 40 (going by the rover spec). This time I will use the oil i found (20 50).
Guess works - I live in the very south (Malmö, beside Copenhagen) so pretty mild and the car doesn't come out of the garage below 4 celsius (no winter tyres fitted).
#10 govig
govig
  • 339 posts
Posted 27 February 2012 - 06:26 PM
Morris 10/40 is a semi-synthetic isn't it? An ordinary mineral oil is better for a Mini
#11 brad-the-bear
brad-the-bear
  • 1,114 posts
Posted 27 February 2012 - 07:13 PM
you can get 10w/40 in mineral
#12 L400RAS
L400RAS
  • 2,479 posts
  • Local Club: Lincolnshire Mini Owners Club
Posted 27 February 2012 - 07:16 PM
You mean 4k - right? 4k=4000 miles, 40k = 40,000 miles...
#13 reallybig
reallybig
  • 613 posts
Posted 27 February 2012 - 07:39 PM
yup i meant 40,000 miles :D
#14 brad-the-bear
brad-the-bear
  • 1,114 posts
Posted 27 February 2012 - 11:59 PM
O_O O_O O_O O_O
#15 minimissionary
minimissionary
  • 999 posts
  • Local Club: Fylde Mini Club
Posted 28 February 2012 - 12:07 AM
I suppose it's like those old ladies that smoke and drink heavily all their lives, yet still live to the age of 96. Think I'll stick to changing mine every 4 months though.
