Arch/wheel Clearance
3 replies to this topic
#1 bc130
bc130
  • 65 posts
  • Local Club: Irish minis, the mini forum
Posted 05 March 2012 - 07:34 PM
I fitted a set of sportspack replica archs from mini spares to my mini a few months ago. Today i finally got a set of 13 x 7 superlites and on fitting them i have discovered a major problem. The back is fine but the front ones are getting caught on the arch. I can only turn the wheel about half a turn before they get caught in the sportspack arch. The wheel isnt centre in the arch either.I have hi los and i tried adjusting up the height but this still doesnt clear the arch. Also, i have fitted new suspension cones and knuckle joints so these are not the problem either, Could anyone help with this.
#2 bluesprite
bluesprite
  • 282 posts
Posted 05 March 2012 - 07:47 PM
Did you trim your wings? you have to cut some of the metal away before you put your arches on
http://www.minisport...nstructions.zip
#3 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 05 March 2012 - 07:51 PM
have you had the tracking reset since you altered the ride height ?
have you fitted a sports pack rack or fitted lock stops to the rack ?
Edited by Bungle, 05 March 2012 - 07:51 PM.
#4 bc130
bc130
  • 65 posts
Posted 05 March 2012 - 08:27 PM
Ya i trimmed the wings. They are not the problem do. I cant even get the wheel in under the sportspack arch.They are getting caught in the front of the arch.
No i havnt had the tracking done yet bungle but if the tracking was out the wheel should still tuck in under the arch shouldnt it. No i have no limiters fitted. I did get a set of KAD limiters but after putting one on, it was very loose on the rack so had to take them off again.
