New K&n Air Filter? Is It Worth It?
8 replies to this topic
#1 srh007
srh007
  • 44 posts
  • Local Club: No
Posted 05 March 2012 - 10:35 PM
Hi,
I have a standard 1975 Mini 1000, and it has the standard air box with the standard air filter, I was thinking about putting a new K&N air filter in, do you think I would, for £25 notice any performance increase that would be noteworthy, or would there be better use for my £25??
Help please?!
Thanks!!
#2 oltonlad
oltonlad
  • 2,401 posts
Posted 05 March 2012 - 10:43 PM
i personally wouldn't bother with the k&n replacement element as you will only see a performance gain with a k&n when it is in conjunction with a stage 1 kit.
#3 srh007
srh007
  • 44 posts
  • Local Club: No
Posted 05 March 2012 - 10:46 PM
Really, ok, my local motor factors, who didn't stock the part, but advised that it probably would slightly increase my performance, but you think different?
#4 oltonlad
oltonlad
  • 2,401 posts
Posted 05 March 2012 - 10:51 PM
a k&n air filter provides more air and in turn you will have to add more fuel otherwise the engine will run too lean....and for the engine to make use of the extra air/fuel ratio the engine needs burn it and then get rid of it efficiently.................which it wont do through a standard exhaust system as it is too restrictive.
#5 MiniFTW
MiniFTW
  • 697 posts
I agree with olton on this, for what its worth you wont notice a great deal of difference. If the element needs replacing then go for it as they are a quality filter but performance wise there wont be much there.
#6 srh007
srh007
  • 44 posts
  • Local Club: No
Posted 05 March 2012 - 11:00 PM
Right, ok then ,thanks! That has saved me a few bob!! What is the cheapest thing I can get then to make a slight bit of difference to the performance please?
Thanks for your advice!
#7 oltonlad
oltonlad
  • 2,401 posts
Posted 05 March 2012 - 11:06 PM
there isn't really a "cheap" way of getting performance, i would just save up for a bit and get a stage 1 kit, or even buy secondhand.....but don't use an LCB manifold on a 998 engine, get a cooper freeflow manifold, they give more torque than an LCB.
get a decent 1 3/4 exhaust and an alloy inlet, you can use this with your standard air filter for now than fit a k&n later on.
you should get the lot for less than £100 secondhand.
#8 TopCatCustom
TopCatCustom
    Previously known as C4NN0N.
  • 1,134 posts
Posted 05 March 2012 - 11:46 PM
Personally I think most people would struggle to feel any difference by bolting a K&N filter on any engine, where it already has a clean air filter and is running well. I've had 3 on different cars and pretty sure any difference I think I felt has been imaginary. Other mods like decent manifolds, ROLLING ROAD, will see much more bang for your buck.
A session on the rollers will be best for any car as it won't affect your insurance as it's not a modification, and I bet 95% of mini's would benefit from a tune up session with noticeable difference in power and fuel economy!
#9 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 06 March 2012 - 07:19 AM
a cheap thing to make your mini go better
a full service and tune up
