Looking For A Specific Part (New)
8 replies to this topic
#1 SamMayfair1996
SamMayfair1996
  • 193 posts
Posted 05 March 2012 - 11:33 PM
Hi guys,
I have a 1996 Mayfair 1.3 auto, and my reverse lights haven't been working for months.
I have found the part I need but noone seems to supply it anymore, so if anyone knows where to get it I would really appreciate it.
I need a part under the number, 13H5045, it is a Switch inhibitor change selector, and need a new one really as i dont want second hand a it to run out a few months down the line.
If anyone knows where to get one that would be awesome :)
Cheers.
#2 mini-luke
mini-luke
    Postman Pat
  • 2,362 posts
Posted 05 March 2012 - 11:37 PM
Not sure if it's actually in stock, but it's listed: http://www.southlake...5045-p-334.html
#3 carboy001
carboy001
  • 1,065 posts
Posted 05 March 2012 - 11:47 PM
I know you said new but beggars can't be choosers
http://www.classicmi...sdetail/104/876
#4 SamMayfair1996
SamMayfair1996
  • 193 posts
Posted 05 March 2012 - 11:53 PM
Cheers guys, unfortunately I rang SouthLake earlier and although it says available its not lol.
And thanks for the other link I saw that but would be gutted to pay £25 and it die soon and be back to square one. May have to if I cant get one though, or atleast for now until the next mini show jumble :)
#5 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 06 March 2012 - 09:59 AM
The starter inhibitor switch has nothing to do with your reverse lamps, and on your car the inhibitor switch is mounted at the front ot the transmission itself where the selector cable attaches. You need a reverse lamp switch, the same as the one fitted to manual cars.
#6 SamMayfair1996
SamMayfair1996
  • 193 posts
Posted 06 March 2012 - 10:51 AM
I bought one of these, however my mechanic pointed the problem towards the switch that is in the centre of the tub underneath? A cylinder at the end of a bolt with two spade like prongs with connections coming from both?
#7 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 06 March 2012 - 01:01 PM
That sounds like an inhibitor switch alright, but the inhibitor was only related to the reverse lights during 1965. Every auto Mini since has had separate inhibitor and reverse switches. In 1992 the inhibitor switch was moved from the gear change to the transmission itself. Definitely a 1996 car? The reverse lamp wires are green on one side and green/brown on the other side of the reverse switch. The inhibitor switch is wired with white/red wires when fitted at the selector, or black and white/light green when fitted to the transmission. Check which switch is which.
#8 minimat
minimat
  • 690 posts
  • Local Club: anglian mini club
Posted 06 March 2012 - 01:24 PM
Sometimes the connectors from the switch come apart,these are inside the car under the carpet.
#9 SamMayfair1996
SamMayfair1996
  • 193 posts
Posted 06 March 2012 - 01:47 PM
The wires from the part in the middle of the tub are both black and attatch onto flat prongs. The reverse switch i bought which i thought i would be fitting underneath .has two green wires, so neither of these things sound right from what you've said.
Yeah definitely a 1996 mini mayfair automatic but the inhibitor is where I said in the middle. :/
