Burnt Exhaust Valve
4 replies to this topic
#1 Keith Grendahl
Keith Grendahl
  • 89 posts
Posted 06 March 2012 - 12:33 AM
1275 A, 12G1316 Austin America Smog Head
As you can see I burned an exhaust valve in cylinder 2. The other 7 valves all look fine, just need lapping.
I had hardened seats pressed in and multi-angle grind done about 4,000 miles ago. Does the seat look like it can be ground to fit a new valve or should I get have another seat in standby? I'll need to order the valve and am wondering if I should order another seat at the same time?
I assume I had that tappet set incorrectly or a bit of debris got trapped in the valve. Any other theories?
Keith
Attached File  seat.jpg   141.75K   38 downloads
Attached File  Valve.jpg   57.29K   32 downloads
Edited by Keith Grendahl, 06 March 2012 - 12:38 AM.
#2 tiger99
tiger99
  • 8,584 posts
Posted 06 March 2012 - 05:40 PM
Or mixture too weak, so combustion temperature is too high. That used to be the cause many years ago, but I think valves are made from better material now, so it is rare.
#3 Keith Grendahl
Keith Grendahl
  • 89 posts
Posted 06 March 2012 - 06:54 PM
The common theme so far is that it was more common years ago. The engine is from the late 60's or early 70's. I ordered a new valve, it will be interesting to compare it to the older valves this engine has. Maybe I should have ordered 4 new valves.
#4 Cooperman
  • 23,326 posts
Posted 06 March 2012 - 07:01 PM
A light 'kiss' with a seat cutter should clean it up OK. Then just lap in a new valve and 'jobsagoodun'.
#5 bmcecosse
bmcecosse
  • 9,699 posts
Posted 06 March 2012 - 07:43 PM
That seat will be fine - new valve - and set the exhaust valve gaps to 15 thou in future - and check/reset regularly.....
