13S To 10S Gear Ratios, Final Drives And Speedometer - In Simple Terms.
3 replies to this topic
#1 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 06 March 2012 - 10:06 AM
I want to change my 13s to 10s, but nothing is ever simple!
The car is a cooper SPi, i don't know the current ratios or final drive but i assume it will be the same as all spi coopers.
I had a look on Guessworks ration calculator, which is great! But can someone put it in simple terms for me.
Dropping to 10s will mean:
The acceleration is slower?
Lower top speed?
Higher rpm on the motor way (bad for fuel economy)?
How bad will the speedo be out?
#2 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 06 March 2012 - 10:36 AM
SO engine code is 12A2EK71 - which according to guessworks is
Source Vehicle : Mini Cooper Spi (Japan) Engine type & CC : A+ 1275 cc Transverse mounted Fueling : Engine features : Air Conditioning 10.1:1 Compression Ratio Gearbox features : Std. Ratio Rod Change gearbox with Pot Joints 3.21:1 Final Drive
Although its not a japanese model with aircon, but a late german export SPI.
#3 TheOriginalMiniator
TheOriginalMiniator
  • 137 posts
Posted 06 March 2012 - 06:35 PM
This is the converter which you need!! I've used it for all my alloy wheel changes!
http://www.kouki.co....size-calculator
assuming your using a 175/50/13 currently and are changing to a 165/70/10
Your speedo at 30mph = 28.8mph actual
Your speedo at 60mph = 57.6mph actual
Edited by TheOriginalMiniator, 06 March 2012 - 06:40 PM.
#4 Bishop IRL
Bishop IRL
  • 109 posts
Posted 07 March 2012 - 12:11 AM
My speedo is reading the other way round!
My speedo at 30mph = 34mph actual
Im on 10's and as she is an '86 Mayfair, was probably on 12's when new!!!
