Is there any need to use the normal turbo inlet manfold other that to line up the plenum with the turbo outlet or could i use a normal HIF 44 manifold as i will be fiitin an intercooler so the turbo and plenum will not need to line up cheers
Turbo Inlet Manifold
03jkirk
, Mar 09 2012 03:01 PM
8 replies to this topic
Posted 09 March 2012 - 03:01 PM
Posted 09 March 2012 - 04:57 PM
Are you using the Metro Turbo ex manifold ? If so you'll probably find that besides the flanges being a completely different thickness, most NA manifolds won't clear the ex manifold.
Phil.
Phil.
Posted 09 March 2012 - 05:07 PM
I am using a GT17 turbo and will be getting a mirage manifold for this i am currently only at the stage of collectin parts but i have an oselli touque master manifold that i wouldlike to use on the project as goin to be a show car aswell i the oselli manifold adds that lil bit extra to the engine bay
Posted 09 March 2012 - 08:40 PM
That's fine then. It should fit if you're using the Mirage.
Posted 09 March 2012 - 09:17 PM
thats good then just wanted to check wasnt gonna affect the fuelin with the volume of air with it bein pressurised
Posted 09 March 2012 - 11:16 PM
My opinion is that the metro turbo manifold does aid fuel distribution on blown setups. But plenty of peope use the non-metro-urbo manifold without issue.
Posted 10 March 2012 - 08:54 AM
Ye have thought bout it but might keep the oselli for wen i change to injection rather than the standard carb cheers
Posted 10 March 2012 - 04:46 PM
Actually, it's even more important to use a log style manifold (like the metro turbo one ) on a wet manifold injection system. It really helps with fuel distribution.
Posted 10 March 2012 - 05:25 PM
ohh ok then
