Tachometer - Pulling My Hair Out Here!
7 replies to this topic
#1 mini-luke
mini-luke
    Postman Pat
  • 2,362 posts
Posted 11 March 2012 - 12:15 PM
After the shambles of the £18 eBay tachometer that according to the seller won't work with Mini's (after I'd found out it didn't work!) I ordered a TIM tacho. Wired it in temporarily, green to coil -, red to + and black to earth I found it won't work at all bar a slight flicker of the needle around 0 rpm.
I think it's defective, but before I send it back does anybody have any other ideas? It's on an SPI, but I know that's not the problem as I know people with the same tachometer on SPI's.
#2 freshairmini
freshairmini
  • 1,718 posts
Posted 11 March 2012 - 12:22 PM
Are you sure that you've wired it into the correct place. Maybe an picture would help.
#3 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 11 March 2012 - 12:26 PM
is there a switch on the back for the number of cylinders ?
#4 mini-luke
mini-luke
    Postman Pat
  • 2,362 posts
Posted 11 March 2012 - 12:33 PM
Yes, it's on 4. Changing it just makes the flickering slower.
It's got a coil like this:
It's a ducellier if you can't read the writing. I connected the green to the left negative terminal and the red to the right positive. I also tried using an alternate 12v source, to no avail.
#5 mini-luke
mini-luke
    Postman Pat
  • 2,362 posts
Posted 11 March 2012 - 04:04 PM
Tried it on a different Mini (thanks Alex!). Still nowt, so I have pronounced it dead.
#6 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 11 March 2012 - 04:05 PM
You typed an update while I was typing. I was going to suggest what you did... trying it on another car.
Sorry this one appears t be DOA.
EDIT: Where did you connect the black (earth) wire from the tach?
Edited by dklawson, 11 March 2012 - 04:06 PM.
#7 mini-luke
mini-luke
    Postman Pat
  • 2,362 posts
Posted 11 March 2012 - 04:07 PM
We tried it on various clean bolts in engine bay, nothing produced anything more than a ficker.
#8 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 11 March 2012 - 04:10 PM
One last suggestion and I know that you have checked this before... probably multiple times.
Regardless of how the coil is marked, you want the green sense wire connected to the coil terminal where the white/black wires are connected. (This will be the coil terminal with the wire going off to the distributor).
