Brake System Leak Help!
8 replies to this topic
#1 minidave1991-89
minidave1991-89
  • 406 posts
  • Local Club: Charnwood Minis
Posted 11 March 2012 - 06:44 PM
Hi all,
Just finished the front end refurb (i thought) but hit a problem. I've installed Goodridge braided hoses on the front with refurbed calipers and sprung a huge leak on the drivers side. It appears to be coming from the banjo union where it connects to the braided hose.
I've tightened everything up but it is still leaking when i press the brake pedal down. When i was fitting the drivers side hose i think i may have disgarded the locking washer with all the rubbish that came out of the subframe. Could that be the problem?
Any help would be a God send!
Cheers Dave
#2 new_van_man
new_van_man
  • 207 posts
Posted 11 March 2012 - 06:46 PM
you need the copper washer
#3 minidave1991-89
minidave1991-89
  • 406 posts
Posted 11 March 2012 - 08:07 PM
Anyone know what size it is as websites just say that its a shakeproof washer part no. WE600101
#4 tiger99
tiger99
  • 8,584 posts
Posted 11 March 2012 - 08:11 PM
It is NOT a shakeproof washer. I did see that same error on a website recently. There MUST be two COPPER washers on a banjo, one each side. They are likely to be 3/8", but it should be easy to measure the diameter of the banjo bolt.
But there will be a large shakeproof washer on the outer thread of the hose end fitting, under the nut, to prevent it loosening in the subframe.
Edited by tiger99, 11 March 2012 - 08:13 PM.
#5 tiger99
tiger99
  • 8,584 posts
Posted 11 March 2012 - 08:17 PM
Oh, and someone else found recently that the two hoses are not identical, one is for a banjo, and the other for a male 3/8 UNF and single flare. If that is the case with the Goodridge hoses, they will be unsafe if they are on the wrong side, as the simgle flare will not be sealing agains a female cone, nor will the banjo be sealing against a sufficiently flat face. But I don't know if the Goodridge hoses are handed.
#6 minidave1991-89
minidave1991-89
  • 406 posts
Posted 11 March 2012 - 08:22 PM
Is there anyway of finding out which hose goes on which side? just ordered the copper washers which go on each side of the banjo and a shakeproof.
Edited by minidave1991-89, 11 March 2012 - 08:23 PM.
#7 tiger99
tiger99
  • 8,584 posts
Posted 11 March 2012 - 08:38 PM
Yes, IF they are different. They could be made to take either type of fitting, which would be very sensible.
It is difficult to see reliably, so feel down the hole with something soft, thin and pointed like a cocktail stick, If the bottom of the hole is a female cone, it is ok for a male nut and single flare.
Look at the top face where the banjo seats. Has it been machined flat? Then it is ok for a banjo.
I think it was traditional reinforced rubber hoses which were found to be handed, and we have not yet established whether that also applies to Goodridge, so here is your chance to enlighten us, depending on what you find.
#8 tiger99
tiger99
  • 8,584 posts
Posted 11 March 2012 - 08:40 PM
By the way, you need two shakeproofs, one each side of the car, unless you have one already. But the banjo is only on drivers side, as you know.
#9 minidave1991-89
minidave1991-89
  • 406 posts
Posted 11 March 2012 - 08:52 PM
Ok well thats the job for tomorrow then. I'll get back to you on what i find
