Spotlights Wobble
13 replies to this topic
#1 brad-the-bear
brad-the-bear
  • 1,114 posts
Posted 11 March 2012 - 10:45 PM
hello, got the 2 up 2 down set-up on the mini and after a ride with the lights in place they seam to move/pivot and no matter how tight i do up the brackets on the lights they still move. ive been told about stay bars but how would i use them on the 2 lower lights?? help would be appreciated!! :D
brad
Edited by brad-the-bear, 11 March 2012 - 10:46 PM.
#2 mk3 Cooper S
mk3 Cooper S
  • 5,569 posts
Posted 11 March 2012 - 10:51 PM
What make of lights are they?
What gauge is the spotlight brackets?
#3 Cooperman
  • 23,340 posts
Posted 11 March 2012 - 10:52 PM
Hi Brad,
The 'spotlight wobble' is one of the reasons why a lot of rally cars have them in a row across the grille. Then it's easy to fit lamp steadies. I know this won't help in your case, but it looks as though it would be easier to support the lower lights with a steady from the bottom of the lamp casing to the bumper or front panel flange.
That might stop them all wobbling, but supporting the top ones will be a problem. How about changing to 4-in-a-row across the front like the 'works' cars.
#4 brad-the-bear
brad-the-bear
  • 1,114 posts
Posted 12 March 2012 - 07:43 AM
Hi Brad,
thought about it, but am too attached to the 2 up 2 down look, but i see where you are coming from
how do you find out the gauge the brackets are???? >_<
oh and ive got 2 sim's and 2 rally giant's they are fantastic :D
#5 mini-luke
mini-luke
    Postman Pat
  • 2,362 posts
Posted 12 March 2012 - 07:47 AM
Measure them to find out what gauge it is. I've got mine attached with rover brackets, and they're prone to a little wobbling at high speed, nothing that causes problems though.
#6 sabaxter
sabaxter
  • 62 posts
Posted 12 March 2012 - 09:02 AM
I think all spotlamps wobble no matter what, unless there mounted in the grill as stated. I put a piece of adhesive foam block in the back to stop them witting the grill but also prevent them shaking violently. regards
#7 oliver122
oliver122
  • 1,007 posts
Posted 12 March 2012 - 09:51 AM
ive got cibie oscar +'s , 2 up 2 down and they only time they move is when mates bump into them , but then they only move half the time , i never seem to have spotlight wobble
Edited by oliver122, 12 March 2012 - 09:51 AM.
#8 Tahiti Joe
Tahiti Joe
  • 663 posts
Posted 12 March 2012 - 10:04 AM
In fairness buddy i think its gonna be more down to the sheer size and then make of your spotlights. Had Rally giants before and the brackets that they were mounted on were pretty crappy.
Use Cibie Oscars on the Cooper S in a 2 up 2 down and never had any wobbling even when giving it some serious stick. Use Wipac spots on my Tahiti, again in 2 up 2 down, and these never wobble either, in fact to even get them too move you have too loosen them right off! :P
#9 mk3 Cooper S
mk3 Cooper S
  • 5,569 posts
Posted 12 March 2012 - 11:57 AM
Yes the shell gauge or Cbies is much better than most and therefore you get less wobble than most.Also the gauge or thickness of the brackets help.
I used to run steady bars to my 20/20'S attached to the bonnet.
Do you have a std front of a fiberglass/flip front?
#10 brad-the-bear
brad-the-bear
  • 1,114 posts
Posted 12 March 2012 - 09:55 PM
standard front =]
do you have a picture of your brackets? =]
thanks for the reply guy's... its appreciated
brad.
#11 oliver122
oliver122
  • 1,007 posts
Posted 13 March 2012 - 06:10 PM
here you go : http://s1230.photobu...t light mounts/
#12 brad-the-bear
brad-the-bear
  • 1,114 posts
Posted 13 March 2012 - 08:42 PM
here you go : http://s1230.photobu...light%20mounts/
ahh cheers pal, got the same brackets as you but painted black, I'll buy some rubber washers/spacers and see if that helps
#13 Cooperman
  • 23,340 posts
Posted 13 March 2012 - 10:34 PM
It is very distracting when rallying and driving flat out if the spotlights wobble or vibrate.
Looking at that bracket it seems that the lights sit well forward of the front panel/grille and this can't help really.
Remember also, if you are doing road rallies only 2 additional lights are permitted. With good driving lights and strong bulbs I do find that 2 are sufficient anyway. I've used 4 extra lights on international historic events at night, taking the lamp bar off for the daylight stages to prevent damage, to allow more air to the oil cooler and to save weight.
#14 brad-the-bear
brad-the-bear
  • 1,114 posts
Posted 14 March 2012 - 07:00 AM
yeah the brackets are solid as a rock!!! no movement at all, just ordered some lock washers too so I'll give that a go
