Would You Use Gasket Cement On Engine Rebuild?
11 replies to this topic
#1 TheOldOne
TheOldOne
  • 95 posts
Posted 12 March 2012 - 10:02 PM
Hi All
As the heading.Where and where not to use and which type please.
Tony
#2 Sam Walters
Sam Walters
  • 2,765 posts
Posted 12 March 2012 - 10:16 PM
hylomar blue. Places like, rocker cover gasket, timing case gasket.
Dont use on head gasket and places where clearences are critical.
#3 sledgehammer
sledgehammer
  • 3,098 posts
Posted 12 March 2012 - 10:40 PM
I only use it around half moon seal on crank cap
and bit on the joints where 2 gaskets meet & gear selector seal
it can cause problems if a lot is squeezed out inside the engine , and breaks off
as the oil strainer tends to clog a bit and bits can get into oil gallery's
(all my opinion)
Edited by sledgehammer, 12 March 2012 - 10:40 PM.
#4 tiger99
tiger99
  • 8,584 posts
Posted 13 March 2012 - 09:25 AM
I agree with sledgehammer about where it is needed, particularly at the junction between gaskets, at both ends of the engine to gearbox joints, etc. You don't really need it anywhere else, but some people, including me, use it on one side (top) of the rocker cover gasket, and allow it to harden somewhat before fitting the cover. That way, the gasket stays located as you fit it (they often try to pop out, or in, along the long sides), and you can get it off cleanly, when you need to adjust the tappets and re-torque the head. With care, you can use the rocker gasket at least 6 times, maybe more, if you don't overtighten the two bolts.
#5 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 13 March 2012 - 11:04 AM
Use a very small amount of RTV on the lower half of both sides of the front plate and timing cover gaskets. Or use a late model gasket here as the MPi versions have the RTV built in so the dose is exactly right.
#6 JustSteve
JustSteve
    Puke-Boy!!
  • 1,883 posts
Posted 13 March 2012 - 11:07 AM
I always use gasket sealant (like hylomar) on anything other than head gaskets. Only a tiny amount, so that it doesn't go inside, but enough to make me feel happy that I've done all that I can. It's not critical, but I do.
On the rocker cover gasket, I put sealant between the cover and gasket, to keep it in place as one-peice... on the other I use grease so that the gasket doe't 'break up' and I can re-use it without any faff.
#7 jaydee
jaydee
  • 8,565 posts
Posted 14 March 2012 - 11:09 AM
+1
and use sealant between rocker cover and cork gasket.
#8 Cooperman
  • 23,286 posts
Posted 14 March 2012 - 01:11 PM
I do put a smear of Hylomar on the timing cover gasket.
#9 Gunnsie
Gunnsie
  • 294 posts
Posted 14 March 2012 - 01:23 PM
Is instant gasket OK to use between the rocker and a cork gasket?
Chris
#10 Cooperman
  • 23,286 posts
Posted 14 March 2012 - 01:24 PM
Chris
Yes, Instant Gasket is just an RTV rubberised sealant.
#11 jaydee
jaydee
  • 8,565 posts
Posted 14 March 2012 - 01:29 PM
As long as its good at holding the gasket in place..
#12 Gunnsie
Gunnsie
  • 294 posts
Posted 14 March 2012 - 09:13 PM
Chris
Excellent... I'm changing mine this weekend now I've stripped and painted the old rocker.
Cheers!
Chris
