Heater Matrix Seal Leak
16 replies to this topic
#1 chrisandsarah
chrisandsarah
  • 746 posts
Posted 13 March 2012 - 01:18 AM
Rover Mini 1992 City
Heater matrix is leaking a the point where the bit that the hoses join on to - joins on to the matrix... I am assuming that there is a diddy gasket inbetween...
Is there - and if so - where can I get one, or is it just a replacement job?
Thanks guys!
#2 brad-the-bear
brad-the-bear
  • 1,114 posts
Posted 13 March 2012 - 06:41 AM
get some silicon sealant (high temperature) or gasket maker, worked for me :proud:
#3 reallybig
reallybig
  • 613 posts
Posted 13 March 2012 - 08:51 AM
get bypass hose fool :D
no gasket seen on the somerford explody thing
http://www.somerford...page=page&id=99
Edited by reallybig, 13 March 2012 - 08:52 AM.
#4 Kerrin
Kerrin
  • 1,056 posts
  • Local Club: Manx Mini Register
Posted 13 March 2012 - 09:00 AM
There is a rubber o ring on each alloy pipe which seals them, but it is possible the alloy is rusted through which may be the problem.
You can get new brass (I think, it's been a while since I did mine) pipes and o rings from mini spares if necessary.
You may get away with just new o rings but if it's your daily driver and the heater matrix is ok get the new pipes.
Edited by Kerrin, 13 March 2012 - 09:01 AM.
#5 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 13 March 2012 - 10:58 AM
Depends which heater is fitted. 1992 is a change point for heaters, it could be either the late heater with two seperate metal pipe stub outlets or it could have the twin plastic outlet plate with the two diagonally split pipes.
#6 freshairmini
freshairmini
  • 1,718 posts
Posted 13 March 2012 - 11:27 AM
Well if its got plastic outlets its a new o ring, same happened to me and it fixed it. No Need for SILICONE. Especially if using it with rubber, as it eats rubber and it'll leak in no time.
If its metal, and its leaking, then take it out for closer inspection, could have rusted.
#7 reallybig
reallybig
  • 613 posts
Posted 13 March 2012 - 11:52 AM
it's the one with two pipes at the bottom on the right hand side of the matrix
(chris is being too slow) :D
#8 chrisandsarah
chrisandsarah
  • 746 posts
Posted 13 March 2012 - 12:20 PM
It is the twin plastic rather than the later one
#9 reallybig
reallybig
  • 613 posts
Posted 13 March 2012 - 12:26 PM
this is pic of his heater matrix
#10 chrisandsarah
chrisandsarah
  • 746 posts
Posted 13 March 2012 - 12:33 PM
Cheers semibig for the pic :P
Its leaking between the plastic bitty and the matrix - it sort of bows out a little - the plastic looks warped
#11 freshairmini
freshairmini
  • 1,718 posts
Posted 13 March 2012 - 12:34 PM
this is what you need (x2): http://bit.ly/wIwIFX
just make sure two surfaces are clean.
#12 reallybig
reallybig
  • 613 posts
Posted 13 March 2012 - 12:49 PM
are these: http://www.minispare...id=42458&title= in the pipes?
#13 chrisandsarah
chrisandsarah
  • 746 posts
Posted 13 March 2012 - 12:53 PM
Really??? Just undo those little diddy bolts and put those in?
I think those are for later mini matrix
#14 freshairmini
freshairmini
  • 1,718 posts
Posted 13 March 2012 - 12:59 PM
Yep Just that. I had a similar problem with mine, two new washers and it no longer leaked. No need for any sealant.
#15 chrisandsarah
chrisandsarah
  • 746 posts
Posted 13 March 2012 - 01:06 PM
Parts have been ordered :D - are those diddy bolts easy enough to get off?
