Straight Cut Drop Gears
Posted 15 March 2012 - 10:38 PM
I dont know much about gearboxes and want to put straight cut drop gear in my gearbox, can i put straight cut drop gear in a standard box or will i have to get a full straight cut gear set?
cheers tom
Posted 15 March 2012 - 10:39 PM
Posted 15 March 2012 - 11:45 PM
Posted 15 March 2012 - 11:50 PM
Anyway, you will get annoyed at the sound soon enough.
Posted 15 March 2012 - 11:51 PM
LMFAO poor OP!!!!
Yes slap some straight cut drops in your mini mate, you will gain a little less side loading and a slightly improved resistance in power transfer.
Posted 16 March 2012 - 06:05 PM
Posted 16 March 2012 - 06:27 PM
just make sure to get the tolerances right etc etc. as these gears can become ineffective unless set up correctly:P
but the straight cut box with the gear cluster is AWSOME:P cant beat the sound of a straight cut mini
Posted 16 March 2012 - 09:08 PM
Posted 16 March 2012 - 10:13 PM
The gears inside the gearbox are seperate things altogether..but can also be straight cut if desired..These ones are not straight cut..
Edited by AndyMiniMad., 16 March 2012 - 10:14 PM.
Posted 16 March 2012 - 11:00 PM
Posted 16 March 2012 - 11:03 PM
hi thanks everyone that helps a lot, and im hopefully going to be running at about 160bhp
you will need a full straight cut box if you are running that ammount of power, i wouldn't fancy putting 160bhp through a helical box.
Posted 16 March 2012 - 11:43 PM
Totally agree, the gearbox WAS over-engineered but remember, it was designed for less than 40BHP! 160 is a lot of power to throw through the standard helical box.
Posted 17 March 2012 - 01:14 PM
http://www.minispare...id=36035&title=
Posted 17 March 2012 - 05:47 PM
I would say a helical box could take it with s/c drops, but everything would have to be in A1 condition. Helical gearboxes are getting old and tried now so its less likely for them to survive the power being put through them than they would of done 5/10 years ago.
Edited by Pauly, 17 March 2012 - 05:50 PM.
Posted 18 March 2012 - 11:49 PM
For peace of mind i would be using a s/c box.
Edited by george91, 18 March 2012 - 11:51 PM.
