Best And Cheapest Way To Light Up A Garage
mohammed
, Mar 17 2012 05:00 PM
7 replies to this topic
Posted 17 March 2012 - 05:00 PM
Hi all,
well I am going to use my sister garage to do some bodywork, what is the best way to light the inside up.. the garage is not connected to the house its at the end of the garden. Will need to got power by pluging into the main socket (extention).
thanks
mohammed
thanks
mohammed
Posted 17 March 2012 - 05:04 PM
Get loooooooooods of torches
candles?
Posted 17 March 2012 - 05:05 PM
White paint
Posted 17 March 2012 - 05:06 PM
Iv got a 30 meter extension cable reel & a couple of work lights which i bought from toolstation :)
http://www.toolstati...0/sd2480/p27678
They are VERY bright, so you might only need 2 depending on how big your garage is!
Edited by abe46, 17 March 2012 - 05:07 PM.
Posted 17 March 2012 - 05:12 PM
Seriously, reflecting any light helps loads & will also seal the dust into the walls rather than drop it in your paint job. If you can run in an extension lead, get a couple of fluorescent tubes at the top of both long walls: you & the car will cast shadows if you have just one in the middle of the roof.
Posted 17 March 2012 - 05:17 PM
any LED lights are incrediably bright and use very little power and almost last forever so gettin some mains powerd ones would be ideal also LED inspection lamps are a good idea and i would highly recomnend these:
http://www.machinema...tails/010815228
they are increabily bright and are equiped with a hook and magnets on the bak so you can stick them to underside of ur bonnet and it jus floods the engine bay with light
they also only run off 4 AA batteries and last for months
Edited by 03jkirk, 17 March 2012 - 05:18 PM.
Posted 17 March 2012 - 05:18 PM
Just put up a couple of 8' strip lights wired to a plug. Simple and cheap.
