Side Entry Distributor Cap
8 replies to this topic
#1 MGBailey007
MGBailey007
  • Validating
  • 725 posts
  • Local Club: North West Mini Club
Posted 17 March 2012 - 07:34 PM
does the side entry distributor cap fit on a normal distributor or do you need the distributor to go with it?
http://www.minispare...ty=pb&pid=38691
i know it says to use a 45D type distributors is that standard on any models? and how will i know what distributor i have on already
Thanks Matt
#2 Simont
Simont
  • 198 posts
  • Local Club: Thames Valley Mini Club
Posted 17 March 2012 - 11:15 PM
i use a 45d cap on my 59d distributor and it works perfectly, and they fit on standard distributors
Simon
#3 MGBailey007
MGBailey007
  • Validating
  • 725 posts
Posted 17 March 2012 - 11:55 PM
Simon
How do i know what distributor i have? will it say on it? and when you used the 45D cap did you change your rotor arm because it says you need the GRA2128 rotor arm
#4 Ethel
  • 26,088 posts
Posted 18 March 2012 - 12:03 AM
The 45 & 59 are essentially the same. If this is your condenser Posted Image it's one or the other.
#5 MGBailey007
MGBailey007
  • Validating
  • 725 posts
Posted 18 March 2012 - 12:06 AM
thanks, so its just the condenser whats different in the distributors?
Matt
#6 Ethel
  • 26,088 posts
Posted 18 March 2012 - 12:45 AM
No, if yours has a wire like that it's either a type 45 or a 59 dizzy - there's a minor difference in the points they use. As above the caps ('n many other bits including the condenser) are interchangeable
#7 MGBailey007
MGBailey007
  • Validating
  • 725 posts
Posted 18 March 2012 - 12:48 AM
ok cheers mate i will check when im home (in 2 weeks) i will let you know what i find... i do have electric points though does that change anything?
#8 Ethel
  • 26,088 posts
Posted 18 March 2012 - 12:59 AM
Probably not,
Google up some piccies of the Lucas type 25 that's the only likely alternative if it's not factory fitted electronic (65dm4) and they went out in the early 70's.
Type 25 cap has a big "arch" to fit over the wire entry insulator
#9 MGBailey007
MGBailey007
  • Validating
  • 725 posts
Posted 18 March 2012 - 08:01 AM
ok so the side entry dizzy cap if for the old distributors?
