Need Some Input
Posted 17 May 2004 - 09:09 PM
It's not a cheap sub, and its by a reputable manufacturer and the quality is very good, this isnt just for watt numbers.
Powered by an amp also running 1200W RMS at 1 Ohm.
What I want to know is what speakers do I get for the front?
The maximum I can give them is 125W RMS x 2 at 4 ohms, but most speakers that im looking at dont even get to 100W RMS.
I'm looking at the Focal line, and perhaps RF FNQ3146 3-way component set.
The system will be pricey so I want some quality speakers up front, but I also do want them to be able to keep up with the sub.
The sub will rarely be turned up very high, but the higher i can turn it up without drowning the speakers, the better.
D'you think putting a second set of components in the back would help with midrange volume? Although this would mean i have to get 2 cheaper amps and 2 cheaper components than 1 good of each...
Given I have the sub, would 5.25" comps do fine up front, or should I really go for a 3 way with 6.5", 4" and a tweeter?
Posted 17 May 2004 - 09:10 PM
Posted 17 May 2004 - 09:40 PM
Posted 17 May 2004 - 10:17 PM
thanks, rob
Posted 18 May 2004 - 04:54 AM
Speakers getting blown is not an issue.
What I want is some speakers that are high quality (i need quality more than loudness) that wouldn't get drowned by the 1kW sub
Posted 18 May 2004 - 06:59 AM
Sorry to ask some stupid questions :erm: :erm:
Posted 18 May 2004 - 07:57 AM
1200W IS a lot... It's VERY a lot.
Ohms are the unit of resistance in electrics. The higher the resistance the harder it is for current to flow through whatever. High resistance = high heat (think kettles and the like).
Smaller resistance allows more power to go through amp/speakers, but it causes more distortion which is why before even hi-end car audio rarely went below 4Ohms. However, nowadays with technology, 2 and 1 Ohm operations are made possible with minimum harmonic distortion.
Hertz are the frequency of the sound. 1 hertz = 1 vibration per minute. The alternating current in your socket in your house is about 50Hz. This means that the electricity changes direction 50 times every second.
The lower the frequencey in hertz, the deeper, lower the sound. Bass is around 30-50 hertz. Vocals and musical stuff is much higher... 500Hz, 1kHz and higher, with hats and cimbals (very high pitched drums) being the highest frequencies. The young human ear can hear from about 20 to 20,000Hz. With most people the upper boundary drops to 15,000 at middle age. This of course depends on how much damage you do to your ears.
Basically the more watts your system has, the louder it will be. However, this can often lead to bad quality, which is why you see all this overpriced equipment, its not because its SO powerful, its because it still sounds good when cranked that high.
Unless you're an audiophile, a set of components and a small sub perhaps will more than do enough for you. Even a set of comps up front and 6x9s in the back will probly appeal to you enough (and by the price too
Posted 18 May 2004 - 03:51 PM
Posted 18 May 2004 - 04:01 PM
As for front speakers definately get some components.. i would reccomend FOCAL as these are pretty good altho a few names like Fusion etc are coming thru with TOP end ICE. Running 125w RMS through these small speakers is a hell of a lot. And im guessing its going to be very loud. As for Mid range .. you can buy specialist mid range drivers from people like FOCAL that you could stick in the back... running from the headunit you will probably blow these up as they are not designed to run with such a low wattage at a high volume so it would be much better to get ALL speakers amped IMO...
Also is this going in ur mini?? To get the BEST performance from all this sound system that you must be spending $$$ on you will need to thoroughly sound proof it as it DOES make a difference. HOPE THIS HELPS
Nick
Posted 18 May 2004 - 04:05 PM
Al* if you are planning on Running 1200w RMS from the amp to the sub at 1ohm and 1 channel my first advise is your going to need COOLING.. BOOOY its gonna get hot. It will be extremely BASSY but you would be a LUNATIC to turn up the gain with that set up on the sub..
Nick
Al
Posted 18 May 2004 - 04:06 PM
sorry Al* ive lost it
Hope this helps Pavel :tongue:
Posted 18 May 2004 - 04:50 PM
As for cooling, i will not be running this system at loud volumes for long at all.
And thanks, that cleared up a lot that 125W through some comps will be loud enough to keep up with the sub
Also are fusion good? They're on the cheap side...
Rockfords FNQ 3146 fanatic 3 way comps are what im looking at now. and they only take 100W RMS, so can get a cheaper sub!
Posted 18 May 2004 - 07:42 PM
I spose i should know that though (I'm a physics student). I understood about hertz because i remember my school physics teacher explaining why electric at 50Hz can kill because it makes your heart try to beat that fast!!
Cheers mate :grin:
Posted 18 May 2004 - 09:04 PM
Components at front with your spare 125w from amp. It is very important to get the best quality tweeter and mid up front and they should be amped. This gives really good sound quality and means you can have a really basey set up at back (which yours will be) and still have a good range up front to suit different styles of music
Posted 18 May 2004 - 10:08 PM
dont buy any 6x9`s if you can get away with it, if your after SQ
