Ballast Wire Removal Help
6 replies to this topic
#1 SA MINI
SA MINI
    Previously known as shaunarmes.
  • 1,001 posts
  • Local Club: yet to join HAMOC
Posted 20 March 2012 - 10:16 AM
Hi I'm after some advice (preferably step by step)
On getting rid of a ballast system & changing it to a 12v system on my mates 998 mini please ?
#2 Ethel
  • 25,966 posts
Posted 20 March 2012 - 10:26 AM
I wouldn't bother, unless there's a fault with the wire - measure the resistance, it should be 1.5ohms.
If you do remove it you'll need a new unballasted 12volt, coil - just connect its +ve to a white wire on the fuse box (not via a fuse). The pink/white & yellow/white wires can be removed.
#3 SA MINI
SA MINI
  • 1,001 posts
Posted 20 March 2012 - 10:42 AM
i have got electric points & 12v unballasted coil to go on will this work if i do the above then ?
#4 Ethel
  • 25,966 posts
Posted 20 March 2012 - 10:46 AM
Yes, you'll just need the +ve from the "electric points" hooked up to +ve side of the coil as well as your new "white" wire.
#5 SA MINI
SA MINI
  • 1,001 posts
Posted 20 March 2012 - 10:47 AM
ah ok thanks a lot for the help :D
#6 cal844
cal844
  • 9,624 posts
  • Local Club: TFMOC
Posted 20 March 2012 - 11:15 AM
easy way to do ut is just disconnect the 2 wires mentined above and just tape them to the loom. i also disconnected my resistor multiplug(gold cylinder shaped thing mounted on n/s bulkhead infront of the tower mount.)
#7 Ethel
  • 25,966 posts
Posted 20 March 2012 - 11:20 AM
The bulkhead resistor you refer to sounds like the headlamp dim/dip ballast, not part of the ignition.
