How To Replace Spindle Bushes On A Su
10 replies to this topic
#1 booton
booton
  • 913 posts
Posted 23 March 2012 - 04:51 PM
In the middle of rebuilding my su 1" 1/2 and I can't seem to find a way to remove the bushes.
cant seem to find a way to remove them.
I've done all the vizs mods and it looks good.
Just don't want to do any damage.
#2 booton
booton
  • 913 posts
Posted 23 March 2012 - 05:43 PM
i've just found out now that i need a 3/8 reamer.
so an item for my shopping list. lol.
unless anyone in south wales could borrow me one.
#3 ACDodd
ACDodd
  • Mini Docs
  • 2,767 posts
Posted 23 March 2012 - 06:49 PM
No a 3/8" reamer is too large, you actually need a 9.2mm drill followed by a 9.5mm parallel reamer. The 3/8" us 9.52mm which is actually too big.
AC
#4 booton
booton
  • 913 posts
Posted 23 March 2012 - 07:51 PM
Does it have to be a parallel reamer or will a spiral one work. So 9.5 instead of a 9.52.
Does 0.02 really make that much of a difference. Thanks for the advice.
#5 tiger99
tiger99
  • 8,584 posts
Posted 23 March 2012 - 08:49 PM
A parallel reamer just means that it reams a parallel-sided hole, same diameter for most of its length. You get taper reamers for tapered holes to take things like track rod ends, or to enlarge holes in sheet metal. I expect you have seen one of these.
The way the blades curve is not important. You may find that hand and machine reamer blades spiral in opposide directions, and some are straight, but any of those will do the job.
The 0.02 matters very much, you do not want an air leak which will ruin the mixture.
Edited by tiger99, 23 March 2012 - 08:50 PM.
#6 booton
booton
  • 913 posts
Posted 23 March 2012 - 10:09 PM
Thanks very much. Will order one if my mate doesn't have one.
#7 tiger99
tiger99
  • 8,584 posts
Posted 23 March 2012 - 11:04 PM
http://www.tapdie.co...s__hss_met.html
http://www.tracytool...ategory&path=20
These may be cheaper than automotive suppliers.
#8 Dusky
Dusky
  • 5,322 posts
Posted 24 February 2015 - 08:40 AM
Wich reamer is needed for HS2 carbs?
#9 Ethel
  • 26,104 posts
Posted 24 February 2015 - 10:43 AM
Pretty sure it'll be the same. See if the bushes are the same on Burlen's site.
#10 ACDodd
ACDodd
  • Mini Docs
  • 2,767 posts
Posted 24 February 2015 - 04:59 PM
You need a 5/16" reamer for the HS2.
Ac
#11 ACDodd
ACDodd
  • Mini Docs
  • 2,767 posts
Posted 24 February 2015 - 05:00 PM
Ac
