Drum Brakes Again
Posted 28 March 2012 - 08:44 PM
Posted 28 March 2012 - 08:49 PM
Posted 28 March 2012 - 09:08 PM
Posted 29 March 2012 - 05:21 PM
any comments please prefer helpfull ones though lol.
This IS an internet forum you know...?
Posted 29 March 2012 - 06:00 PM
Posted 30 March 2012 - 12:15 PM
Posted 30 March 2012 - 08:52 PM
The piston (both in a dual circuit system) must return fully to open the reservoir port(s), otherwise hydraulic pressure becomes trapped in the system. It also prevents bleeding the system in the normal way, although a pressure bleeder may sometimes apply sufficient pressure to overcome the problem temporarily.
There seem to have been a few people chasing round in circles recently with their clutch systems, when the problems they were describing pointed to exactly the same problem.
Posted 31 March 2012 - 11:04 AM
Posted 31 March 2012 - 12:14 PM
You can do a simple test. Jack up a wheel so you can feel for locked brakes. Undo the two master cylinder fixing nuts and lift it up as far as the hydraulic pipe allows. If the pressure is now released, the cause is proved.
Your best bet is to carefully consult the Somerford web site to see which bits you have, or should have. It may be that something, such as the wrong brake light switch, is preventing the pedal returning fully. There is not much access to the top of the pedals and the master cylinder push rods, as you will know, having fitted a pedal box, so it may be difficult to pin this down, but it may be that you need one or more spacer plates to lift the master cylinder slightly. NAM1718 on the Somerford web site are used in pairs, quantity "as required", which to my mind says that adjustment is often needed. I assume you have the gasket fitted, as its thickness may make all the difference, and you need it to keep fumes from entering the car. There perhaps should be a gasket under the plate which carries the cylinders and top engine steady too.
There should be a trace of free play between the push rod and master cylinder piston when the pedal is fully up, and all dimensions are correct, but I don't know how you would be able to feel it in there.
I should have asked if you have a direct acting servo, because that is between pedal and master cylinder, and could cause the problem. Also, the pedals and the pedal box are very different.
http://www.somerford...page=page&id=57
Posted 31 March 2012 - 12:45 PM
Posted 28 November 2015 - 09:23 AM
I've got exactly the same issue with my mini. Did the fitting the spacers fix the problem?
Posted 28 November 2015 - 11:02 AM
Due to refitting master cylinder without the gaskets above and below the engine steady plate.
Why is this thread entitled "DRUM" brakes?
84 Mayfair has discs?
Posted 28 November 2015 - 04:56 PM
