Full Dash Fitting.......
11 replies to this topic
#1 Badboytunes
Badboytunes
  • 1,615 posts
  • Local Club: MINIS Unleashed
Posted 29 March 2012 - 08:02 PM
Evening all,
After seeing lots of Mini's with full width dashboards and cc's my partner has decided that one needs to go into the classic.
Custom Console's ( whom we chatted to @ Bingley ) have some nice ones. Are they particulary difficult to fit? Im no noob to using spanners and tools ect but just wanted a heads up.
Are there any other / better products on the market that can be recommended.
#2 Stitch306
Stitch306
  • 106 posts
Posted 29 March 2012 - 08:33 PM
I fitted one a couple of months ago and it was really easy, I'd only had my mini a couple of months and am definitely not an expert. Had 3 brackets on the back that clamp it onto the dash rails. 2 bolts on each bracket with big wing nuts on them to do up by hand. 2 of them I just reached through the glove box opening to do up, the drivers side one was a bit fiddly as you have to reach up from underneath but the wing nuts are easy enough to do by touch.
#3 MGBailey007
MGBailey007
  • Validating
  • 725 posts
  • Local Club: North West Mini Club
Posted 29 March 2012 - 08:35 PM
no mine has about 5 brackets on it and you just tighten up the wing nuts and it clamps itself in you don't need any tools apart from a screw driver to screw your clocks to the back
#4 Algordo1100
Algordo1100
  • 774 posts
Posted 29 March 2012 - 08:37 PM
Cc's like custom console's examples just screw together around the heater. They clamp themselves in like this and are a doddle to fit.
Dashes are a little more complicated, but still straightforward. They have U shaped brackets that clamp behind the bottom and top rails. Doing up the nuts is fiddly as it has to be done through the glove box and instrument cluster hole. The instrument cluster is usually a separate bit that goes in after. Good designs ive seen have a clip on one side, and a wing nut on the other so you can tighten it by hand. (through the eyeball vent) If you are keeping the eyeball vents then you will need to extend the ducting out behind them (pringles tube method) . If your clocks are the Nippon Seiki type (mid eighties on) then you will also need to cut the plastic tubes down where the indicators are so they fit flush.
Hardest part of dash fitting I always found was re-attaching the speedo cable.
Al
#5 Badboytunes
Badboytunes
  • 1,615 posts
Posted 31 March 2012 - 12:02 PM
Thanks for the comments guys. Will be getting one soon and im eager to fit it.
Thanks again for the swift replies.
#6 Badboytunes
Badboytunes
  • 1,615 posts
Posted 15 August 2012 - 09:00 PM
Ordered a dash from Custom consoles at MITP. Hoping it wil arrive on Friday. New seats ( Cobra recliners ) were ordered too. Looks like a busy weekend, just got to order some extra dials :proud:
#7 Doovydoo
Doovydoo
  • 231 posts
Posted 17 August 2012 - 08:10 AM
Mine is a dashboard from Custom Consoles too, fits well and looks great I think.
#8 Badboytunes
Badboytunes
  • 1,615 posts
Posted 02 September 2012 - 07:34 AM
Im making headway but it doesnt say how the original dials are secured,. Do you just screw them in place?
#9 Doovydoo
Doovydoo
  • 231 posts
Posted 02 September 2012 - 10:31 AM
Yes, just screw them through the original clock mounting holes into the back of the wooden dash with a few screws (usually supplied with the dash).
#10 Badboytunes
Badboytunes
  • 1,615 posts
Posted 02 September 2012 - 08:43 PM
All done, bloody pain in the arse lol.
Top rail was mounted too tight, forgot to reconnect speedo :shy: and the clock is slightly darker than the rest. Wierdly with the dash in place its harder to see the speedo ect as they sem to be angled downwards slightly. However, thats minor issue, its virtually done, just a cpl of adjustments to do next weekend when im back at my girlfriends.
I am pleased with the results though, pics to follow once uploaded to photobucket. :)
#11 i_am_neg
i_am_neg
  • 31 posts
Posted 29 November 2012 - 11:17 PM
I'm having a hard time with my Custom Console. I ordered a dash fascia and centre console. I have yet to do the dash fascia (i thought that would be the hard part) but the centre console is proving to be a right pain. The right panel needed a little alteration to fit in properly, but my current problem is that it seems the heater control is too low. Of all the mini's ive seen and pics on the net, the heater control is flush to the underside of the rail but mine is about an inch lower? Does anyone have any ideas as to why its lower than normal? Or if i can raise it up somehow? If it fits flush then I can secure the middle panel of the centre console to the 2 side panels. Currently im driving round with half a console. O_O
#12 JustJack
JustJack
  • 87 posts
Posted 14 February 2013 - 07:37 PM
have the screws come loose or missing from the heater that attach it to the lower dash?
