Nice Job Tomorrow
Posted 30 March 2012 - 10:55 PM
It's not been on the road since January and needs a very full service plus annual Waxoyling. Full engine service including removal of opil cooler to ensure all old oil is drained out, partial strip of twin H4's for clean out and re-setting-up, distributor clean & points change, new plugs, adjust all valve clearances and general engine inspection. Then full suspension and steering check and grease. Braking system check/adjust and grease cable runs and brake fluid change (AP600 race fluid), check and re-set ride height to standard +1/2" raised, full systems check (bulbs, lights, instruments, interior/map lights, electric fan, etc). Pump up tyres to 32 psi.
The re-charge battery, put in the fresh 20w50 oil , warm it up, adjust carbs and give it a test run doing a 0 - 60 and a max revs in top gear test up to around 6800 rpm.
Then clean and polish inside & out.
It's so enjoyable to me to do this and Grandson will be over after lunch to help.
Posted 30 March 2012 - 11:00 PM
Posted 30 March 2012 - 11:09 PM
Posted 30 March 2012 - 11:10 PM
Sounds like a weeks work to me
No kidding. I've seen less work take up it's own rebuild thread!
Posted 30 March 2012 - 11:13 PM
Posted 30 March 2012 - 11:14 PM
Posted 30 March 2012 - 11:21 PM
Posted 30 March 2012 - 11:25 PM
Fun though!I can take it to the Gliding Club on Thursday and test it on the peri-track.
Posted 31 March 2012 - 05:59 AM
Posted 31 March 2012 - 10:16 AM
Posted 31 March 2012 - 06:03 PM
wax oil is lovely stuff. Just dont get it in your hair. I did and I looked like a 1950's greaseball for the next 2 weeks..
It smells nice as well, but I guess that will be gone after I soak in the bath shortly!
Got almost all of it done. The horn doesn't work when the steering wheel centre button is used, but it works using the button on the navigatort's panel, so it's something simple. Engine started and ran well after I re-set the carbs a bit. Oil pressure is great, suspension is all greased and has no play in it anywhere.
All-in-all a satisfying days work. I'll road test it on Monday morning. Nice to have it all serviced though.
